Minmin Guest
| Qustion on I2c for 16F877A/16F877 |
Posted: Wed Aug 11, 2004 8:04 pm |
Hi all,
A few month ago, I write code for PIC 16F877 i2c, which works fine, Today my boss ask me to write I2c for PIC 16F877A, it didn't produce any signal. My question is simple, is there any code I need to add just for PIC16F877A.
Following is PIC16F877A I2c , if I replace 16F877.h, the same code works for PIC16F877.
#include <16f877A.H>
#fuses hs, NOPROTECT, BROWNOUT, PUT, NOWDT, NOLVP
#use delay(clock= 20000000)
#use i2c(Master,fast,sda=PIN_C4, scl=PIN_C3, FORCE_HW)
#byte SSPADD = 0x93
main ()
SSPADD = 0x07;
output_float(PIN_C3);
output_float(PIN_C4);
i2c_start();
i2c_write(0x1E);
i2c_write(0x0f);
i2c_start();
i2c_write(0x1f);
i2c_read(0);
i2c_stop();
Minmin |
Posted: Thu Aug 12, 2004 12:17 pm |
| Quote: | A few month ago, I write code for PIC 16F877 i2c, which works
fine. Today my boss ask me to write I2c for PIC 16F877A, it didn't
add just for PIC16F877A. |
I tested the 16F877A with PCM vs. 3.207, and it worked OK.
I got pulses on pins C3 and C4.
I changed your program so it would be a better test program.
I set it to do a continous i2c_write(), so that I could easily
see the pulses on my oscilloscope. Try the following program
with the 16F877A and see if it works for you. (Change the clock
frequency and XT fuse, as required to make it work on your board).
If it doesn't work, then post your version of the compiler.
| Code: | #include <16F877A.H>
#fuses XT, NOPROTECT, BROWNOUT, PUT, NOWDT, NOLVP
#use delay(clock= 4000000)
#byte SSPADD = 0x93
main()
SSPADD = 0x07;
i2c_write(0x55);
tag-eng
Posted: Thu Aug 12, 2004 2:09 pm |
i have a questions, kind of similar in that it is involving the i2c and 16f877. i am using the picdem2 plus board and want to read from the temerature sensor on it.
i think i am able to read it but everytime i do i get the same number, 255. knowing that that isn't the temperature, and as well looking at the sensor datasheet that i wouldn't have convert it i am curious why this isn't working.
my code is as follows:
#include <16F877.h>
#device adc=8
#use delay(clock=10000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=RS232,bits=8)
#fuses NOWDT,RC, NOPUT, NOPROTECT, BROWNOUT
#use i2c(Master,sda=PIN_C4,scl=PIN_C3,RESTART_WDT,FORCE_HW)
i2c_Start(); // Set a START condition I2C Bus
i2c_Write(10011010); // Address and Write Flag
i2c_Write(0x01); // Temperature Register
i2c_Write(10011011); // Address and Read Flag
temp = i2c_Read(0); // Read Teperature
i2c_stop();
thanks in advance! |
rnielsen
Posted: Thu Aug 12, 2004 3:11 pm |
| Quote: |
i2c_stop();
Your i2c_write() function is sending an address of 10,011,010 in decimal. If you are going to send a Binary number you need to have '0b' preceeding the number to indicate that it is in Binary. Or, you could use '0x' to indicate a Hex number (0x9A). This might be why it's not working. Try changing the number format and try again. It's always the little things like this that bite people in the butt.
Ronald |
tag-eng
Posted: Fri Aug 13, 2004 6:50 am |
| that was it. and you are correct its always the little things. thanks alot, i appericate it. |
Posted: Mon Aug 16, 2004 11:06 am |
Hey,
Thanks for all the replies, the problem is hardware. I just fix it , Above code works correctly for PIC 16f877A
Minmin |
