Write_Program_Memory command:)
Goto page Previous  1, 2
garyzheng
my packet size is small and is only 10-15 chars.
PostPosted: Tue Aug 10, 2004 2:00 pm     Reply with quote
I had tought about this question, I write the data from 0x0d00 to 0x0e00,
According the datasheet, i can write 16 chars from 0x0d00 to 0x0d10.
So I don't think the data I stored will exceed the page limit.
bdavis
PostPosted: Tue Aug 10, 2004 9:55 pm     Reply with quote
I'm not sure if you need to write the page size - I remember some bootloader code was writing 64 bytes at once. It would be worth a try. If you only need to write a few bytes, you could do a read of 64 bytes modify with the few bytes, then write the full page size. If you get it working, please post it - I would think the example code for the bootloader would work. Also - probably worth reading the app note on doing this from microchip - has some good info, and can be chip specific.
Page 2 of 2
