kloppy
| communicating with li-ion battery |
Posted: Mon Aug 09, 2004 2:45 am |
| i am trying to communicate with an existing li-ion battery through SMbus to get some information about the battery. has someone ever done anything like that? |
kender
Posted: Mon Aug 09, 2004 1:41 pm |
I haven't done anything like this, but I'm currently researching this topic. In case you haven't done this already, you can open your battery pack, find the battery monitor/charger/superviser IC, who's datasheet might have the communication protocol. Also I heard that there is a push for a standard communication protocol for the smart batteries (sorry, I don't rememeber its name).
What kind of battery pack are you hacking?
Sincerely,
Nick |
kloppy
Posted: Mon Aug 09, 2004 2:46 pm |
it's a battery from a notebook.
unfortunately i'm not allowed to open it (the battery) and i also don't know the manufacturer of the battery. so i thought maybe there's a standard protocol for batteries... |
gaul1 Guest
| small-talk with LiIon-Packs over I2C |
Posted: Tue Aug 10, 2004 6:13 am |
I did it a long time ago, with the I2C-Protokoll
it's quite simple, you have 'just' to find out the SDA and the SCL connections.
then you can read the battery similar to an serial EEprom (i.e. 24c04 )
be careful ! you can overwrite the manufacurer name, and the memory, where the configuration is stored for properly charging.
I recommend to make a backup of your battery before changing the memory.
Was this, what you want to know ?
gaul1 |
kloppy
Posted: Tue Aug 10, 2004 7:53 am |
yes, thanks.
but how do i know at which adress i can get which information (manufacturer, cell voltages, etc.)? |
kender
Posted: Tue Aug 10, 2004 12:09 pm |
I'm just curious - are you building a custom charger?
Nick |
kloppy
Posted: Tue Aug 10, 2004 12:24 pm |
| no, i'm trying to build an equipment that can measure the available capacity of a battery and find out how long the battery will work (approximately) in a laptop if it is full charged. |
kender
Posted: Tue Aug 10, 2004 2:27 pm |
On the TI website I came across a fuel gage IC, wich supports a standard called SBS 1.1. Here's the datasheet http://focus.ti.com/lit/ds/symlink/bq2084.pdf . It looks like the description of the stsndard is there.
Nick |
kloppy
Posted: Wed Aug 11, 2004 12:19 am |
| ok thanks, i'm gonna try that |
