PIC 18F452 problem
dijuka
PIC 18F452 problem
PostPosted: Mon Apr 26, 2004 12:49 pm     Reply with quote
I am using PIC 18F452 with CCS v3.179. I haven't been able to get PIN_A4 and PIN_A6 to high. What am I doing wrong?
fpgeh
PostPosted: Mon Apr 26, 2004 1:07 pm     Reply with quote
Pin A4 is an open drain pin. This means it can only drive low. To get the pin high, you will need a pullup reistor to Vcc.
As for pin A6, I'm not sure what the porblem could be. The datasheet does say that on a Power-On Reset pins A4 and A6 are configured as inputs, the rest of port A as outputs.
fpgeh
PostPosted: Mon Apr 26, 2004 1:08 pm     Reply with quote
Sorry, to correct. On Power-On reset, Pins A4 and A6 are configured as digital inputs, the rest as analog inputs.
PostPosted: Mon Apr 26, 2004 1:35 pm     Reply with quote
According to the 18F452 data sheet, to get Pin A6 configured as an
i/o pin, you must use the RC_IO or EC_IO oscillator option.
So in your #fuses statement must use one of those two options,
instead of HS or XT, etc.
dijuka
PostPosted: Mon Apr 26, 2004 3:30 pm     Reply with quote
Thank you for helping out.
Birdasaur
PostPosted: Fri Aug 06, 2004 9:24 am     Reply with quote
After changing the Fuse statement appropriately, how would we access PIN_A6?
add a manual define to your file like
#define PIN_A6 31750
I ask because it isn't really available anywhere in the header file that I see and wouldn't compile otherwise.
Mark
PostPosted: Fri Aug 06, 2004 10:50 am     Reply with quote
That would be one way. You can always manipulate the bits in the registers also.
