dgi
Joined: 07 Jan 2004 Posts: 11 Location: Philadelphia, USA
| pin A6 undefined |
Posted: Tue Mar 23, 2004 2:31 pm |
I want to use pin A6 for IO,
on the PIC18F258.
Inside PIC18F258.h, there is:
#define PIN_A0 31744
#define PIN_A1 31745
#define PIN_A2 31746
#define PIN_A3 31747
#define PIN_A4 31748
#define PIN_A5 31749
but no:
#define PIN_A6 31750
Is there any reason CCS did not include pin A6? Is there any reason I should not add it? |
| Re: pin A6 undefined |
Posted: Tue Mar 23, 2004 2:49 pm |
| dgi wrote: | I want to use pin A6 for IO,
on the PIC18F258.
but no:
The only reason, is because it is not available in normal configurations (you have to be using ECIO). I have used it fine.
Posted: Fri Aug 06, 2004 9:20 am |
How do you setup PIN_A6 once you place your 18Fxxxx in EC_IO?
just add a define like the one mentioned above?
| Code: | | #define PIN_A6 31750 |
maybe to whatever file you're working on?
I tried that and it does compile fine this way.. but I haven't tested it yet. |
Mark
Posted: Fri Aug 06, 2004 10:49 am |
| Yes |
