Nick Guest
| a 5volt regulator cost 5mha in current? |
Posted: Wed Aug 04, 2004 5:39 pm |
I got an LM340T5 5v regulator. I have been working on getting the voltage down anyway I got it down to about 6 mha and couldnt find out where the rest was comming from. So I disconnected everything and it seems like the voltage regulator is costing 5mha, does this sound correct?
Nick |
Will Reeve
Joined: 30 Oct 2003 Posts: 209 Location: Norfolk, England
Posted: Thu Aug 05, 2004 4:11 am |
Don't rule out the 'new' switch mode regulators, the later ones don't need the inductors, just a couple of caps, quiescent current measured in low uA range.
Will |
Posted: Thu Aug 05, 2004 4:19 am |
Will,
I'm looking for something like that but this is the first time I hear of switch mode regulators without inductors. Can you give a few examples of type numbers? |
Will Reeve
Posted: Thu Aug 05, 2004 5:04 am |
The only inductroless one I've used in a product is a MAX1759, a battery project which needed to run in the wild for a year without human contact! Its 100mA max giving 3.3V from 1.6 to 5.5V input, 1uA shutdown Mode, 50uA Quiescent current. I ran it off a single lithium (non rechargeable) cell, worked very well.
I will be searching the Farnell catalogue later this week to find one for another handheld device I am designing to run from 4AA batteries.
Keep well,
Will |
rwyoung
Posted: Thu Aug 05, 2004 7:35 am |
| ckielstra wrote: | Will,
Look around on Maxim-IC's, TI's, Linear Technology for the phrase "charge pump". _________________ Rob Young
davidpk
Posted: Thu Aug 05, 2004 10:14 am |
I looked at the MAX1759 part and it would be really good for loads of less than 20mA. Li-ion cells would be great since their voltage doesn't drop to below 3.6V until they are nearly dead.
The drawback would be the package. It's a big step to go from a TO-220 to a uMAX package. It's a little harder to put on a breadboard! You'll need a circuit board. |
Will Reeve
Posted: Thu Aug 05, 2004 10:32 am |
Indeed, I went straight to PCB for that design, http://www.pcbtrain.co.uk will do a couple of board for 40quid. Takes 10 days but if you get it right (or nearly right!) saves you a lot of time and you have the PCB laid out at then end of it :-)
Will |
Will Reeve
Posted: Fri Aug 06, 2004 7:54 am |
In fact I swapped to the MAX682 because of the uMAX packaging of the MAX1759! I should read me notes better :-) I am now going to use the MAX682 again in the new design as it worked very well. It's still in a bloody small package but at least you can solder it by hand if you are careful. I remember getting a sample of the uMAX package and I could hardly see the gaps between the pins and decided to change to one a little bigger!
Keep well all,
Will |
