my interrupt code and question
Nick
PostPosted: Tue Aug 03, 2004 10:48 am     Reply with quote
I want to put an interrupt on a single pin, the example that comes with CCS does it on an entire RB port with #int_rb.
How do I put an interrupt just on say PIN_RB3?
here is the code I have so far
#include <16F876.h>
#int_rb
void detect_rb_change()
printf("wake up");
   enable_interrupts(INT_RB3);
   output_low(PIN_B0);
   while (TRUE) {
   sleep();
What I'm trying to do is sleep until pin rb3 is set to +5 then say 'wake' and finally go back to sleep again. very simple right? its doable I hope.
Nick
PostPosted: Tue Aug 03, 2004 10:55 am     Reply with quote
PICs aren't Zilog processors. They have limited interrupt capabilities.
You didn't tell what PIC you use. Check out the manual to find out your possibilities (e.g. 16F series have only 1 Ext IT 18F452 (RB0) has 2 (RB0 and RB1) 18F6720 has 4 (pin_b0-3) etc.)
Nick
PostPosted: Tue Aug 03, 2004 1:36 pm     Reply with quote
I c, I looked at the datasheet and it shows RB0/INT I assume that is an interput.
#int_rb does that point to pin rb0?
Many Thanks!
Nick
PostPosted: Tue Aug 03, 2004 1:40 pm     Reply with quote
I did a google search and it pulled up '#INT_EXT'
Thanks!
Nick
PostPosted: Tue Aug 03, 2004 1:49 pm     Reply with quote
btw here is the link good site.
http://www.fernando-heitor.de/pic/ccs-compiler/praeprozessor.htm
rnielsen
PostPosted: Tue Aug 03, 2004 2:09 pm     Reply with quote
For the 16F876 you have three interrupts available for your use. RB0/INT, which is PortB bit 0 (pin 21 on a DIP package), Timer0 and Input Change on PortB bits 7 - 4. This is what is generated when using the Project Wizard if you want to use RB0 as the interrupt:
Inserted into .c file before main():
#int_EXT
EXT_isr()
Inserted into .c file in main():
enable_interrupts(INT_EXT);
The '#int_RB' is used on the PortB 4 - 7 'interrupt on change' interrupt.
Ronald
