Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
MAX197 Driver PIC18F452
dvsoft
PostPosted: Mon Aug 02, 2004 5:40 pm     Reply with quote
bonjour,
My driver for the MAX197
//  Copyright (c) DVSoft 2004
//  email dvsoft@club-internet.fr
//  This program is free software; you can redistribute it and/or modify it
//  under the terms of the GNU General Public License as published by the
//  Free Software Foundation.
//  This program is distributed in the hope it will be useful, but WITHOUT
//  ANY WARRANTY; without even the implied warranty of MERCHANDIBILITY or
//  FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
//  more details.
//  Originale Unit Name : Max197Driver.c
//  Author              : Alain
//  Date                : 15-Avril-2004
//  Project             : YA1-LOGGER-V3
//  Version             : 0.9.0.1
//  Revision            :
// Conditional PinDef
#ifndef __MAX197_PIN_DEF__
    #define MAX197_INT      PIN_B0  //   I      1
    #define MAX197_HBEN     PIN_B2  //   O      0
    #define MAX197_RD       PIN_B3  //   O      0
    #define MAX197_WR       PIN_B4  //   O      0
    #define MAX197_CS       PIN_B5  //   O      0
    #define MAX197_D0       PIN_D0  //  I/O    1/0
    #define MAX197_D1       PIN_D1  //  I/O    1/0
    #define MAX197_D2       PIN_D2  //  I/O    1/0
    #define MAX197_D3       PIN_D3  //  I/O    1/0
    #define MAX197_D4       PIN_D4  //  I/O    1/0
    #define MAX197_D5       PIN_D5  //  I/O    1/0
    #define MAX197_D6       PIN_D6  //  I/O    1/0
    #define MAX197_D7       PIN_D7  //  I/O    1/0
    // tris Def
    #define TRIS_D_IN       0b11111111
    #define TRIS_D_OUT      0b00000000
    #define TRIS_B          0b00000011
    // Fast IO
    #use fast_io(B)
    #use fast_io(D)
#endif
// Max197 Data
#ifdef __YA1_LOGGER_DATA_REGISTER__
    // Max197 driver status
    BOOLEAN     Max197DriverRun;
    // Max197 Data Registers
    int16   AN0Raw;                         // AN0Raw
    #byte   AN0Raw_L = AN0Raw
    #byte   AN0Raw_H = AN0Raw+1
    int16   AN1Raw;                         // AN1Raw
    #byte   AN1Raw_L = AN1Raw
    #byte   AN1Raw_H = AN1Raw+1
    int16   AN2Raw;                         // AN2Raw
    #byte   AN2Raw_L = AN2Raw
    #byte   AN2Raw_H = AN2Raw+1
    int16   AN3Raw;                         // AN3Raw
    #byte   AN3Raw_L = AN3Raw
    #byte   AN3Raw_H = AN3Raw+1
    int16   AN4Raw;                         // AN4Raw
    #byte   AN4Raw_L = AN4Raw
    #byte   AN4Raw_H = AN4Raw+1
    int16   AN5Raw;                         // AN5Raw
    #byte   AN5Raw_L = AN5Raw
    #byte   AN5Raw_H = AN5Raw+1
    int16   AN6Raw;                         // AN6Raw
    #byte   AN6Raw_L = AN6Raw
    #byte   AN6Raw_H = AN6Raw+1
    int16   AN7Raw;                         // AN7Raw
    #byte   AN7Raw_L = AN7Raw
    #byte   AN7Raw_H = AN7Raw+1
#endif
// Max197 Macro
#define Max197Select()     output_low(MAX197_CS)
#define Max197UnSelect()   output_high(MAX197_CS)
#define Max197_RDLow()     output_low(MAX197_HBEN)
#define Max197_RDHigh()    output_high(MAX197_HBEN)
#define Max197RD_On()      output_low(MAX197_RD)
#define Max197RD_Off()     output_high(MAX197_RD)
#define Max197WR_On()      output_low(MAX197_WR)
#define Max197WR_Off()     output_high(MAX197_WR)
#define Max197EnableInt()  enable_interrupts(INT_EXT)
#define Max197DisableInt() disable_interrupts(INT_EXT)
// Max197 Local Data
BOOLEAN Max197EOC;          // Wait for end of conversion
BOOLEAN Max197Pending;      // Convertion running
int16   Max197Row;          // 16 bits Value
#byte   Low  = Max197Row    // Max197 LSB
#byte   High = Max197Row+1  // Max197 MSB
int8    ChannelCnt;         // Current channel
int8    ANShiftBit;         // Current channel Shift Bit Enabled/Disable
// Current test bit channel
int8 ANMaskBitChannels;
#bit AN0MaskBitEnabled = ANMaskBitChannels.0
#bit AN1MaskBitEnabled = ANMaskBitChannels.1
#bit AN2MaskBitEnabled = ANMaskBitChannels.2
#bit AN3MaskBitEnabled = ANMaskBitChannels.3
#bit AN4MaskBitEnabled = ANMaskBitChannels.4
#bit AN5MaskBitEnabled = ANMaskBitChannels.5
#bit AN6MaskBitEnabled = ANMaskBitChannels.6
#bit AN7MaskBitEnabled = ANMaskBitChannels.7
// Function : NextChannel()
// Input    :
//      void
// return   :
//      void
// Modify   :
//      Set the next channel bit
// Note     :
//      Set the first channel if Current Channel+1 > 7
#inline
void NextChannel(void)
    //--- Next Channel
    ChannelCnt++;
    //--- Shift the enabled bit
    ANShiftBit >>= 1;
    //--- Enabled next Channels
    ANMaskBitChannels = (ANMaskBitChannels << 1) & 0xff;
    //--- Last Channel ? (0 to 7)
    if (ChannelCnt > 7) {
        //--- First Channel
        ChannelCnt = 0;
        //--- First channel enabled bit
        ANMaskBitChannels = 0x01;
        //--- Enabled channels bits
        ANShiftBit = EnabledChannels;
    }// End If
// Function : Max197Read(void)
// Input    :
//      void
// return   :
//      void
// Modify   :
//      Store the MAX197 value in Low an High
// Note     :
//      Don't forget the waitstate befort read the MAX197 DataBus
#inline
void Max197Read(void)
    //--- Port D read
    set_tris_d(TRIS_D_IN);
    //--- Max197 Select
    Max197Select();
    //--- RD = 0
    Max197RD_On();
    //--- Wait 120 ns befort read (TD0)
    delay_cycles(2);
    //--- Store low Value
    Low = input_d();
    //--- HBEN = 1
    Max197_RDHigh();
    //--- Wait 120 ns befort read (TD1)
    delay_cycles(2);
    High = input_d();
    //--- HBEN = 0
    Max197_RDLow();
    //--- RD = 1
    Max197RD_Off();
    //--- UnSelect
    Max197UnSelect();
// Function : Max197Open(void)
// Input    :
//      void
// return   :
//      void
// Modify   :
//      Init the MAX197 Data
//      Set the Max197 driver flag 'Max197DriverRun' to TRUE
// Note     :
#separate
void Max197Open(void)
    BYTE i;
    //--- Unselect
    Max197UnSelect();
    //--- Low Value First
    Max197_RDLow();
    //--- Signal Off
    Max197RD_Off();
    Max197WR_Off();
    //--- Non convertion running
    Max197Pending = FALSE;
    //--- Empty the raw vale
    AN0Raw = 0;
    AN1Raw = 0;
    AN2Raw = 0;
    AN3Raw = 0;
    AN4Raw = 0;
    AN5Raw = 0;
    AN6Raw = 0;
    AN7Raw = 0;
    //--- Loop index
    ChannelCnt = 0;
    //--- Current bit channel
    ANMaskBitChannels = EnabledChannels;
    //--- Driver status
    Max197DriverRun = TRUE;
// Function : Max197Close(void)
// Input    :
//      void
// return   :
//      void
// Modify   :
//      Set the Max197 driver flag 'Max197DriverRun' to FALSE
// Note     :
#separate
void Max197Close(void)
    //--- Driver stop
    Max197DriverRun = FALSE;
    //--- No interruption
    Max197DisableInt();
// Function : Max197Service(void)
// Input    :
//      void
// return   :
//      void
// Modify   :
//      Store the current channel value
//          AN0Raw to AN7Raw
//      Select the next channel
// Note     :
//    Usage in Main
//      Max197Open();
//      while (TRUE) {
//          Max197Service();
#inline
void Max197Service(void)
    //--- Running ?
    if (!Max197DriverRun)
        return;
    //--- Max197 Running convertion ?
    if (Max197Pending) {
        //--- End of convertion ?
        if (!input(MAX197_INT)) {
            Max197Read();
            //--- Channel 0
            if (AN0MaskBitEnabled) {
                AN0Raw_H = High;
                AN0Raw_L = Low;
            }// End IF
            //--- Channel 1
            if (AN1MaskBitEnabled) {
                AN1Raw_H = High;
                AN1Raw_L = Low;
            }// End IF
            //--- Channel 2
            if (AN2MaskBitEnabled) {
                AN2Raw_H = High;
                AN2Raw_L = Low;
            }// End IF
            //--- Channel 3
            if (AN3MaskBitEnabled) {
                AN3Raw_H = High;
                AN3Raw_L = Low;
            }// End IF
            //--- Channel 4
            if (AN4MaskBitEnabled) {
                AN4Raw_H = High;
                AN4Raw_L = Low;
            }// End IF
            //--- Channel 5
            if (AN5MaskBitEnabled) {
                AN5Raw_H = High;
                AN5Raw_L = Low;
            }// End IF
            //--- Channel 6
            if (AN6MaskBitEnabled) {
                AN6Raw_H = High;
                AN6Raw_L = Low;
            }// End IF
            //--- Channel 7
            if (AN7MaskBitEnabled) {
                AN7Raw_H = High;
                AN7Raw_L = Low;
            }// End IF
            //--- Max197 Stop
            //--- Next Channels
            NextChannel();
        }// End IF
    }// End If
    //--- Max197 free ??
    else {
        //--- Channel enabled ?
        if (ANShiftBit & 0x01) {
            //--- Port D write
            set_tris_d(TRIS_D_OUT);
            //--- Select the Max197
            Max197Select();
            //--- Write = 0
            Max197WR_On();
            //--- Configuration + Current Channel number
            // 0 to 5 Volts
            output_d(64+ChannelCnt);
            //--- Write = 1
            Max197WR_Off();
            //--- Max197 UnSelect
            Max197UnSelect();
            //--- Convertion Started
            Max197Pending = TRUE;
        }// End IF
        //--- No goto next channel
            NextChannel();
    }// End Else
