For some reason the CCS compiler is spitting out 1000's and 1000's of errors to the point where the buffer in MPLAB is not large enough to hold them. Thus I have no way of know where the first error is that cascaded into this god awful mess.
I would call tech-less support but getting through to tech support is a pain in the butt and usually they will not return calls or emails...
Trampas
Posted: Fri Jul 30, 2004 12:45 pm
Make sure that MPLAB is set to Halt Build on First Failure.
This is set in the Configure / Settings / Projects menu.
This may not fix it. In that case, comment out all the code
inside main(). Also comment out most of your #include files.
At some point, it will stop giving errors. Then slowly un-comment
code until you find the error.
dyeatman
Too many Error Messages
Posted: Fri Jul 30, 2004 12:50 pm
When I encounter this problem I set the compiler to display only the first error (-E) and work my way through (you may want to add -EW to supress warnings until you get through that).
Usually it is one particular something that triggers all the rest, so when you find it most of the others disappear.
Posted: Fri Jul 30, 2004 2:20 pm
I did turn on halt after first error in MPLAB, but MPLAB seems to think it is one big error.
