Configuration word
Nick
Configuration word
PostPosted: Tue Jul 27, 2004 7:10 am     Reply with quote
I am writing a program for PIC12F629 and I haven't understand which
C instruction use to write the configuration word. I can set it only from IDE menu, but i want to write it with a C instruction because MPLAB IDE doesn't visualize GP3 flag.
Thanks,
Nick
rwyoung
PostPosted: Tue Jul 27, 2004 7:19 am     Reply with quote
Look for #fuses in the help file and also look at the header file for the PIC you have selected.
Rob Young
Nick
PostPosted: Tue Jul 27, 2004 7:48 am     Reply with quote
I have already looked for in included files and help file and there aren't any references about configuration bits.
Mark
PostPosted: Tue Jul 27, 2004 7:54 am     Reply with quote
The #fuse statement is used to set the configuration bits. By looking at the header file, you can see what options are available.
garyzheng
don't think about any control on the special register
PostPosted: Tue Jul 27, 2004 8:25 am     Reply with quote
I think there is no way to control the special register and configuration bits in CCS compiler. All you can do is use its built-in function. The hearder file only include the parameter for built-in function and I/O port parameter:)
SherpaDoug
PostPosted: Tue Jul 27, 2004 8:55 am     Reply with quote
What do you want to do with the configuration word? Maybe if we know we can better help you.
PostPosted: Wed Jul 28, 2004 3:41 am     Reply with quote
My problem is that bit 5 of configuration word select MCLR pin function:
if bit is 1 pin function is MCLR else if bit is 0 pin function is the alternate function (so I think it means pin works as a classic I/O pin) and MCLR is internally disabled.
Thank you for help
Nick
PostPosted: Wed Jul 28, 2004 5:44 am     Reply with quote
I solved my problem with #fuses directive.
Thank you all for help.
Nick
