Parsing a response string from rs232 port
GUEST
PostPosted: Tue Jul 27, 2004 9:52 am     Reply with quote
I want to issue a command through rs232 and store the result as a string.
The problem I have is that the string is formatted with a carriage return and line feed at the begining and end, i.e CRLFResponseCRLF. Is it possible to store the whole thing into a string and retrieve the Response only, or will the carriage return cause nothing to be stored.
Mark
PostPosted: Tue Jul 27, 2004 10:07 am     Reply with quote
Here is an example that may help a bit. I am not posting all the code but data is received and put into a buffer through an ISR. This function is called from main to receive commands
void TerminalHandler()
  static uint8_t  index = 0;         /* index of buffer */
  int           i;                  /* character from buffer */
  char          ch;                 /* character from buffer */
  static char   buf[MAX_LINE_LEN]; /* for the line entry */
  while (TRUE)
    i = HostReadChar();
    /* port error */
    if (i < 0)
      return;
    ch = (char)i;
    switch (ch)
      /* illegal characters */
      case '\a':
      case '\f':
      case '\n':
      case '\t':
      case '\v':
      /* escape */
      case 0x1B:
      /* backspace */
      case '\b':
        if (index)
          --index;
          /* do a destructive backspace */
          HostWriteChar('\b');
          HostWriteChar(' ');
      /* enter */
      case '\r':
        HostWriteChar('\r');
        HostWriteChar('\n');
        buf[index] = '\0';
        /* did we get something? */
        if (index)
          if (!CommandHandler(buf, &CommandData[0]))
            HostWriteRomString("Invalid Command. Type ? for help.\r\n");
        buf[0] = '\0';
        index = 0;
        /* write the prompt */
        HostWriteChar('>');
      /* all the rest of the characters */
      default:
        /* leave room for null at the end */
        if (index < (MAX_LINE_LEN - 1))
          buf[index] = ch;
          if (!ch)
            ch = 0;
          HostWriteChar(ch);
          index++;
Here is the command handler:
static bool CommandHandler(
  char            *pArgs,         /* FIX ME: add comment */
  COMMAND_DATA    *pCommandData)  /* FIX ME: add comment */
  static char cmd[MAX_LINE_LEN];  /* local buffer */
  bool        found = 0;          /* valid command? */
  if (pArgs)
    /* parse and remove the only the first command */
    pArgs = stptok(pArgs, cmd, sizeof(cmd), " ");
    /* find and execute command function */
    while (pCommandData->pStr != NULL)
      if (strcmpipgm2ram(cmd, pCommandData->pStr) == 0)
        if (pCommandData->pFunction != NULL)
          (void)strupr(cmd);
          (void)pCommandData->pFunction(cmd, pArgs);
        found = 1;
      pCommandData++;
  return (found);
And here are the commands:
typedef rom struct  _cmd_t
  const rom char  *pStr;  /* command */
  void (*pFunction) (char *pCmd, char *pArgs); /* command function */
  const rom char  *pDescription;  /* command description (for help) */
} COMMAND_DATA;
static COMMAND_DATA CommandData[] =
  /* hidden commands - description is NULL */
  { { "help"      },   VHelpCommand,     { NULL                     } },
  { { "TEST"      },   SelfTestCommand,  { NULL                     } },
  { { "VIRGINIZE" },   VirginCommand,    { NULL                     } },
  { { "bootmode"  },   BootCommand,      { NULL                     } },
  /* application commands */
  { { "ver"       },   VersionCommand,   { "sofware version"        } },
  { { "abus"      },   ABUSCommand,      { "sends command out abus" } },
  { { "input"     },   InputCommand,     { "input status"           } },
  { { "photocell" },   PhotocellCommand, { "photocell status"       } },
  { { "data"      },   DataCommand,      { "dump program data"      } },
  { { "restore"   },   ReInitCommand,    { "restore defaults"       } },
  { { "restart"   },   RestartCommand,   { "restart device"         } },
  { { "dump"      },   EEPROMDumpCommand,{ "dumps the contents of the eeprom" } },
  { { "host"      },   HostModeCommand,  { "allows this device to act as host" } },
  { { "??"        },   VHelpCommand,     { "verbose help"           } },
  { { "?"         },   THelpCommand,     { "terse help"             } },
  { { NULL        },   NULL,             { NULL                     } },
Not sure how well CCS handles pointers to functions. Also note that since CCS does not allow constant strings the above would not work with CCS and you would have to change it a bit to check for the commands. This code is for the C18 compiler BTW.
SherpaDoug
PostPosted: Tue Jul 27, 2004 12:00 pm     Reply with quote
Bytes is Bytes. You can choose any termination character you want, or none at all if you know how many bytes long the string will be.
In your case you could poll for a <CR> and then read till the next <CR>.
