SIZE OF A FUNCTION ?
YUM
PostPosted: Fri Jul 23, 2004 1:04 am     Reply with quote
Does anyone know, how i can determine the size of a function (subroutine) ?
for example:
unsigned char dummy_function (unsigned char uhu)
In the list file i can only see the starting address, but not the end address.
And what, if the function is splitted into blocks by the compiler ?
Question
Haplo
PostPosted: Fri Jul 23, 2004 1:13 am     Reply with quote
You can see the size of the functions in the statistics file (.sta) if you are using PCW(H). Otherwise you'll need to look into the .LST file.
SherpaDoug
PostPosted: Fri Jul 23, 2004 7:08 am     Reply with quote
You could comment it out and see how much ROM usage shrinks.
Note that a function that is never called is usually optimized out of existence.
rwyoung
PostPosted: Fri Jul 23, 2004 8:10 am     Reply with quote
The end address of a function in the LST file (unless it is for an ISR) will typically end like this:
0182:  GOTO   29B (RETURN)
The tip-off is the
(RETURN)
but the actuall argument to GOTO may vary.
You can then just count words and executions cycles between the start and end of the function.
The statistics file summarizes each function in a table, for example
code]
Page ROM % RAM Functions:
0 16 2 1 @I2C_WRITEU_1_59_60
0 17 3 1 @I2C_READU_1_59_60
0 130 19 0 main
0 90 13 0 Initialize
[/code]
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
