COG-LCD Display Issue
paclark
PostPosted: Wed Jul 21, 2004 3:55 pm     Reply with quote
I'm using the basic 4-bit LCD write function and for some reason with a COG-LCD any chars after the 10th position are reversed. Anyone seen this? Probably simple but I can't figure it out. I can switch to two other 2x16 displays and they work fine. The LCD is from Varitronix and the controller is a Fuji FC2314AK (I assume HD44780 compliant).
void LCD_SetPosition ( unsigned int xVar )
    LCD_SetData ( swap ( xVar ) | 0x08 );
    LCD_PulseEnable();
    LCD_SetData ( swap ( xVar ) );
    LCD_PulseEnable();
void LCD_PutChar ( unsigned int xVar )
        output_high ( LCD_RS );
        LCD_SetData ( swap ( xVar ) );     // send high bits
        LCD_PulseEnable();
        LCD_SetData ( swap ( xVar ) );     // send low bits
        LCD_PulseEnable();
        output_low ( LCD_RS );
MAIN:
    LCD_SetPosition ( LINE_1 + 0);
    printf (LCD_PutChar, "1234567890abcdefghij");
    LCD_SetPosition ( LINE_2 + 0);
Displayed Result:
As you can see I have to enter more than 16 chars before wrap begins.
Any thoughts?
Regards,
Patrick Clark
PostPosted: Wed Jul 21, 2004 4:37 pm     Reply with quote
What's the part number of the Varitronix LCD ?
paclark
PostPosted: Wed Jul 21, 2004 4:56 pm     Reply with quote
The part number is as follows:
COGS-16265S-DP-RC-LV-G
Datasheet is here.
http://solomon.bond.okstate.edu/~paclark/16265S-06.pdf
Thank you,
Patrick
Mark
PostPosted: Wed Jul 21, 2004 5:29 pm     Reply with quote
Looks like they wired the 2nd half of the display backwards!
I hope it was cheap LOL
treitmey
PostPosted: Thu Jul 22, 2004 8:26 am     Reply with quote
Send it back and see how they repond.
Maybe it was a one time mistake.
I know how risky this design stuff is.
I had to order $50 240x64 graphic LCD from hantroncs.
I only had 1 to play with. And our order on 100 had a 13 week lead time.
If anything was wrong,.. I would have been in big trouble.
