Shift << or >> question
rnielsen
PostPosted: Mon Jul 19, 2004 5:19 pm     Reply with quote
I believe that when you do a shift left or right, << or >>, that zero's will always be inserted into the bits that are emptied. For example, if I do this:
variable = 10100111
then
variable = variable << 4;
the result is 01110000.
Is this what you have experienced? I just want to make sure before I try and trust things to work this way.
Ronald
Haplo
PostPosted: Mon Jul 19, 2004 6:13 pm     Reply with quote
Correct. Zeros will be shifted in.
PostPosted: Tue Jul 20, 2004 1:03 am     Reply with quote
For the left shift << it is true that always zero's will be shifted in.
For the right shift >> it is not specified in the C standard and left to the compiler builder. For unsigned data you always want a zero to be shifted in, but for signed data you want to shift in the same bit as already present in the most significant position.
If you want to be sure about the >> operation use the shift_right() function in which you can specify the bit to be shifted in.
Update: Did a small test on the PIC18F458 and PCH3.187.
A zero is always shifted in for both << and >> independent of signed or unsigned data. The shift_right() function is just as efficient as the << or >> operator.
....................   int8 Temp;
....................   unsigned char uTemp;
....................   signed char sTemp;
....................   uTemp = 0;
00EE:  CLRF   19
....................   sTemp = -1;
00F0:  MOVLW  FF
00F2:  MOVWF  1A
....................   uTemp = uTemp >> 1;
00F4:  BCF    FD8.0
00F6:  RRCF   19,F
....................   shift_right(&uTemp, 1, 0);
00F8:  BCF    FD8.0
00FA:  RRCF   19,F
....................   shift_right(&uTemp, 1, 1);
00FC:  BSF    FD8.0
00FE:  RRCF   19,F
....................   sTemp = sTemp >> 1;
0100:  BCF    FD8.0
0102:  RRCF   1A,F
