Lcd-problem occur with 3.205
MSU
PostPosted: Wed Jul 14, 2004 2:44 am     Reply with quote
this driver works fine with 3.190, but it dont work it all with 3.205
i need help!
/thanks
#bit      LcdEnable      =   PORTB.0
#bit      LcdRS         =   PORTB.1
#bit      LcdRW         =   PORTB.2
#bit      LcdD4         =   PORTC.0
#bit      LcdD5         =   PORTC.1
#bit      LcdD6         =   PORTC.2
#bit      LcdD7         =   PORTC.3
#define lcd_type      2         // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two   64         // LCD RAM address for the second line
#define lcd_line_three   16         // LCD RAM address for the third line
#define lcd_line_four   80         // LCD RAM address for the fourth line
byte CONST LCD_INIT_STRING[4] = {(0x20 | (lcd_type << 2)), 0xc, 1, 6};
         // Special characters å/Å/Ä/Ö/g/down-arrow/up-arrow/bargraph test
byte CONST FONT[64]={4,0,14,1,15,17,15,0,  4,4,10,17,31,17,17,0,  10,4,10,17,31,17,17,0,  10,14,17,17,17,17,14,0,
               0,0,15,17,17,15,1,14,  0,14,14,14,31,14,4,0,  0,4,14,31,14,14,14,0,  21,21,21,21,21,21,21,0};
// LCD Send nibble
void lcd_send_nibble( int8 n )
   LcdD4 = n & 1;
   LcdD5 = n & 2;
   LcdD6 = n & 4;
   LcdD7 = n & 8;
   delay_cycles(1);
   LcdEnable = 1;
   delay_us(2);
   LcdEnable = 0;
// LCD Send byte
void lcd_send_byte( int8 address, int8 n )
   delay_ms(2);
   LcdRS = address;
   delay_cycles(1);
   LcdRW = 0;
   delay_cycles(1);
   LcdEnable = 0;
   lcd_send_nibble(n >> 4);
   lcd_send_nibble(n & 0xf);
// LCD Init
void lcd_init()
   int8 i;
   LcdRS = 0;
   LcdRW = 0;
   LcdEnable = 0;
   delay_ms(15);
   for(i=1;i<=3;++i)
      lcd_send_nibble(3);
      delay_ms(5);
   lcd_send_nibble(2);
   for(i=0;i<=3;++i)
      lcd_send_byte(0,LCD_INIT_STRING[i]);
   for(i=0;i<64;i++)
      lcd_send_byte(0,0x40+i);
      lcd_send_byte(1,FONT[i]);
// LCD Goto XY
void lcd_gotoxy( int8 x, int8 y)
   int8 address;
   switch (y)
      case 2:
         address=lcd_line_two;
      case 3:
         address=lcd_line_three;
      case 4:
         address=lcd_line_four;
      default:
         address=0;
   address+=x-1;
   lcd_send_byte(0,0x80|address);
// LCD Putc
void lcd_putc( char c)
   switch (c)
      case 'å':
         lcd_send_byte(1,0);
      case 'ä':
         lcd_send_byte(1,225);
      case 'ö':
         lcd_send_byte(1,239);
      case 'Å':
         lcd_send_byte(1,1);
      case 'Ä':
         lcd_send_byte(1,2);
      case 'Ö':
         lcd_send_byte(1,3);
      case 'g':
         lcd_send_byte(1,4);
      case '\f':
         lcd_send_byte(0,1);
         delay_ms(2);
      case '\n':
         lcd_gotoxy(1,2);
      case '\b':
         lcd_send_byte(0,0x10);
      default:
         lcd_send_byte(1,c);
Haplo
PostPosted: Wed Jul 14, 2004 5:02 am     Reply with quote
If it is working fine with 3.190 but not working under 3.205, it means your code is fine and you are experiencing a compiler bug.
Try to pinpoint the exact location of the problem, and then send it to the CCS tech support so they can fix the bug. In the meantime you can go back to using version 3.190 as it compiles your code fine.
