Futureatwork Guest
Posted: Tue Jul 13, 2004 11:28 am |
C-H Wu:
| Quote: | | Comment: in case of frequent RAM bank selection and switching is required, say, heavy RAM usage, using simple code like cmd = (int8)(address>>8); instead of pointer operation cmd = *(&address+1); avoid this kind of tricky bug. |
In my application, I have some data to move from eeprom to a struct and struct to eeprom. The way it is coded is *(&address+offset) like you said that can cause bugs...
Can you explain how (int8)((address+index)>>8); works? |
Posted: Tue Jul 13, 2004 4:13 pm |
In order to retrieve the high or low byte of an int16 xpercad started with the following code:
| Code: | #define hi(x) (*(&x+1))
#define lo(x) (*(&x))
void write_ext_eeprom(int16 address, byte data)
byte low_byte, high_byte;
low_byte = lo(address); // 14 bytes
high_byte = hi(address); // 14 bytes
Then C-H Wu came with a simpler implementation that is easier to swallow by the compiler: | Code: | low_byte = (int8)(address); // 4 bytes
high_byte = (int8)(address>>8); // 6 bytes |
But why is nobody using the CCS supplied command Make8(var, offset) ?
This can extract a single byte from an int8, int16 or int32 and does this with a single byte move.
| Code: | low_byte = make8(address, 1); // 4 bytes
high_byte = make8(address, 0); // 4 bytes |
Hans Wedemeyer
| Here is a 1 byte version: time for structs/unions again! |
Posted: Tue Jul 13, 2004 6:15 pm |
If your code can tolerate one global variable for the Address then it will only require ONE byte to load the High or Low parts of the Address.
// struct to enable easy access to high and low byte
struct HighLow
char l;
char h;
typedef union HL_TAG
long L;
struct HighLow hl;
}HL16;
HL16 g_Address; // the global address for
void write_ext_eeprom( byte data)
// I have no idea what the orginal user wanted to do with these. Of course the two bytes are not needed. Simply use the g_Address.hl.l and g_Address.hl.h directly, it saves even more space... can I then claim 0 Bytes... :-)
low_byte = g_Address.hl.l; // 1 byte
high_byte = g_Address.hl.h; // 1 byte
int data=0;
g_address = 32000;
write_ext_eeprom( data);
From the LST
.................... void write_ext_eeprom( byte data)
.................... byte low_byte, high_byte;
.................... low_byte = g_Address.hl.l; // 1 byte
0004: MOVFF 05,09
.................... high_byte = g_Address.hl.h; // 1 byte
0008: MOVFF 06,0A
000C: GOTO 002C (RETURN)
C-H Wu Guest
Posted: Tue Jul 13, 2004 8:54 pm |
It is great to know that there are quite a few different ways to do the job!
Here is CCS's reply to xpercad's e-mail: | Quote: | You could also try changing your macros to this:
#define hi(x) (x>>8)
#define lo(x) (x&0xff)
CCS knew where could be the problem, they suggest simple, easy to understand, and robust algorithm.
make8(var, offset) is fast, equivalent to (((var >> (offset*8)) & 0xff), however, it is a CCS dialect. make8() is a good choice if portability is not an issue. The disadvantage, make8() can not be placed at the left hand side of an expression like *(int8 *)(&var+offset) = x.
I did learned a lot through this bug hunting experience.
Cheers !
BTW, Hans, using union is the fastest, but it still need 2 bytes for PIC18, or 1 word, not 1 byte.  |
C-H Wu Guest
Posted: Tue Jul 13, 2004 9:06 pm |
Hi, Futureatwork:
| Futureatwork wrote: | C-H Wu:
Sorry, it won't work.
y = (int8)(x>>8) is equivalent to y = *(&x+offset) only if the variable 'offset' equals to one, which is his case but not your case.
If the code *(&address+offset) does run into bugs of PCH 3.205, try 3.187 with #opt 10, or, wait for 3.206. I am always hesitate to use pointer because I am not good at C programming.
By the way, since you ask me to reply, someone else with better options might hold there just for politeness. It is time to ask them and I am looking forward to learn more.
Best wishes
C-H Wu |
Posted: Wed Jul 14, 2004 2:01 am |
Hi Hans,
| Code: | From the LST
0004: MOVFF 05,09
0008: MOVFF 06,0A
000C: GOTO 002C (RETURN) |
These examples are not taking 1 byte!!! It's 1 instruction, but taking 2 instruction cycles and 4 bytes of code space!!! So your example of using a struct is taking the same amount of ROM space as the make8() function.  |
| however... |
Posted: Wed Jul 14, 2004 7:53 am |
| ckielstra wrote: | Hi Hans,
0004: MOVFF 05,09
0008: MOVFF 06,0A
Yes I mixed instructions with bytes...
Make8() has a very limited use and not is portable, as was pointed out it can't be used on the left side... whereas the struct/union can... |
C-H Wu Guest
| Bug fixed ... in 3.207 |
Posted: Wed Jul 21, 2004 9:22 am |
| Quote: | > Sent: Wednesday, July 21, 2004 9:37 PM
> Subject: Re: PCW Support for 3.206 22330{?}
> This message is a reply to CCS e-mail id: 4G3738
> The problem you reported has been fixed and will be in the
> next compiler release.
Let's wait and see if 3.207 really fixed it.  |
