willie.ar
| sending out hex values thru the rs232 |
Posted: Mon Jul 12, 2004 5:22 pm |
I'm trying to transmit the hex values of a table (or binary values, as you prefer) to the RS232 port and, whatever I do, I get the ASCII values of the chars instead.
Example: If the value of the variable is 10 then I get 2 bytes (31,30).
try this
INT tabla[47]={
1,10,10,10,10,64,65,66,67,68,
69,70,71,72,73,74,75,76,77,78,
79,80,81,82,83,84,85,86,87,88,
87,86,85,84,83,82,81,80,79,78,
77,76,75,74,73,72,71
for (byte_cntr=0;byte_cntr<47; byte_cntr++)
Printf("%02X", tabla[byte_cntr]);
what am I doing wrong ???
following is the full code
#include <16F628.h>
#fuses HS, NOLVP, NOWDT, PUT, NOBROWNOUT
#use rs232(baud=19200, xmit=PIN_B2, RCV=PIN_B1, parity=N, bits=8, errors)
#include <stdlib.h>
#include <input.c>
unsigned int cont,byte_cntr; // 0-255
INT tabla[47]={
char comando;
void main() {
// iniciar variables
cont=0;
printf("reset \r\n");
do {
if(kbhit())
comando=getc();
if(comando=='I') // send data
{output_LOW(PIN_B3);
DELAY_MS(200);
output_HIGH(PIN_B3);
} while (TRUE);
Posted: Mon Jul 12, 2004 5:25 pm |
| Don't use printf(). Use putc() instead. |
Haplo
Posted: Mon Jul 12, 2004 5:27 pm |
If you use
Printf("%c", tabla[byte_cntr]);
you will get only one character with the ASCII value of 10. |
Guest Guest
| A hex on that hex stuff |
Posted: Mon Jul 12, 2004 6:26 pm |
I am writing bytes to EEPROM, and reading them back and checking them with RS-232. I am using the following form of the printf command with success. (PCM version 3.187 I think, don't have the code and stuff with me now)
byte data_byte;
int16 data_address;
data_byte = read_ext_eeprom(data_address);
printf("%2x", data_byte);
Is "%2x" THAT different than "%02X" ?
I got stuck on this once and ended up using "putc()" instead. |
willie.ar
Posted: Mon Jul 12, 2004 9:14 pm |
thanks all of you for your quick response.
putc() works fine. I didn't try it before because the reference manual says the parameter should be an 8 bit character, so it`s a bit confusing...
also what Haplo says refers to a char (it works too).
the ASCII character chart included in the ref manual just define chars up to dec 127 only, that`s why I thought that char did not refer to the hole range.
thanks again.
W |
