SHT11 Code Debugging
YASAS
PostPosted: Mon Jul 05, 2004 4:21 am     Reply with quote
I need to read data from SHT11 throw computer parallel port(I'm connect to sensor pin2 to parallel port pin15,14 and sensor pin3 to parallel port pin16.
I downloaded freeBSD program If I convert it into windows platform
but it did not work (Output "Device timed Out !!")
does someone con debug my coding?
Regards,
yasas
My coding----
#include <stdio.h>
#include <dos.h>
#define DeviceTimeout 20
#define ReadTimeout 200
//pin 14 : out: bit 2 of 0x37a
//pin 15 : in: bit 8 of 0x379
//pin 16 : out: bit 4 of 0x37a
int Data(int Level) {
outportb(0x37a,(inportb(0x37a)&4) + 2*(!Level));
delay(1*1000);
return (inportb(0x379)&8)==8;
void Clock(int Level) {
outportb(0x37a,(inportb(0x37a)&2) + 4*Level);
delay(1*1000);
void Bus_Init(void) {
int Cnt;
//Initiate bus
outportb(0x378,0xff);
Data(1);
Clock(1);
//Connection reset sequence
for (Cnt=0; Cnt<9; Cnt++) {
Clock(0);
Clock(1);
int Bus_Read(unsigned char Command) {
int Cnt;
int Time;
int ReadData;
//Transmission start
Clock(1);
Data(0);
Clock(0);
Clock(1);
Data(1);
Clock(0);
//Send address & command
for (Cnt=0; Cnt<8; Cnt++) {
if (((Command >> (7-Cnt))&1)==1)
Data(1);
Data(0);
Clock(1);
Clock(0);
//ACK
Data(1);
Clock(1);
Time=0;
while ((Data(1)==1) && (Time++<DeviceTimeout))
delay(1*1000);
if (Time>DeviceTimeout)
printf("Device timed out!!!%c\n",0x07);
Clock(0);
//Wait for the SHT11 to get it's data ready
Time=0;
while ((Data(1)==1) && (Time++<ReadTimeout))
delay(1*1000);
if (Time>ReadTimeout)
printf("Measurement timed out!!!%c\n",0x07);
//Now clock 2 bytes of data in...
ReadData=0;
Clock(1);
ReadData<<=1;
if (Data(1)==1)
ReadData|=1;
Clock(0);
//ACK
Data(0);
Clock(1);
Clock(0);
Data(1);
Clock(1);
ReadData<<=1;
if (Data(1)==1)
ReadData|=1;
Clock(0);
//!ACK
Data(1);
Clock(1);
Clock(0);
return ReadData;
#define Cmd_ReadTemp 0x03
#define Cmd_ReadHum 0x05
int main(void)
//FILE *IO = fopen("G:\progport\a\io.txt","r");
int TempData;
int HumData;
float Temp;
float Humidity;
/*if (IO==NULL) {
printf("could not open /dev/io");
Bus_Init();
TempData=Bus_Read(Cmd_ReadTemp);
HumData=Bus_Read(Cmd_ReadHum);
Temp=TempData*0.01-40.0;
Humidity=-4.0 + 0.0405*HumData - 2.8*HumData*HumData/1000000;
printf("temp: %.2f hum: %.2f\n",Temp,Humidity);
//fclose(IO);
return 0;
jds-pic
Re: SHT11 Code Debugging
PostPosted: Wed Jul 07, 2004 6:51 pm     Reply with quote
your answer is here:
http://www.ccsinfo.com/forum/viewtopic.php?p=29127&highlight=#29127
and here
http://216.239.51.99/
jds-pic
Haplo
PostPosted: Wed Jul 07, 2004 7:19 pm     Reply with quote
Your code is converted from FreeBSD, it contains a lot of outportb() and inportb() function calls. I'm not sure if Windows allows reading/writing to the ports directly. You program will probably work fine under pure DOS.
The best way for you to solve this is probably to search Google for a parallel port OCX for Visual basic. I know a couple of free ones are around. They should allow you to read/write the port easily.
http://rspsoftware.clic3.net/rspppc.htm
