MPLAB build fail with simple prog
PostPosted: Wed Jul 07, 2004 9:45 am     Reply with quote
Build from Mplab 6.5 with below gives the following error:-
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\App\prog\pic\PICC\Ccsc.exe" 925941sw.c +FM
No Errors
Skipping link step. Not all sources built successfully.
BUILD FAILED: Wed Jul 07 16:47:52 2004
#include "16F87.h"
Strange, isn't it since there is nothing to link. Any suggestions to what may be wrong?
Re: MPLAB build fail with simple prog
PostPosted: Wed Jul 07, 2004 9:55 am     Reply with quote
Clean: Done.
No Errors
#include "16F87.h"
You have the MPLAB setup wrong. In the 'language tool' selection, there is an option for 'CCS C Compiler', and a second one for 'CCS C Compiler for PIC12/14/16/18'. If you select the first of these, you get the error you are seeing. Select the second, and it works. You need to have run the 'CCSC /setup' option to get the second shown...
