		| Author | Message |
		| young
				| 10bit a/d conversion |
				|  Posted: Wed Jul 07, 2004 7:35 am |   |
				| I have the following program: #if defined(__PCM__)
 #include <16F877a.h>
 #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
 #include <lcd420_1.c>
 #include <math.h>
 void main() {
 int i, min, max;
 int16 val1,val2,val3;
 float Total;
 //lcd has to be cleaned before corectly position data on it
 printf(lcd_putc,"                ");
 lcd_gotoxy(1,1);
 printf(lcd_putc,"Avitech LLC:");
 setup_port_a( ALL_ANALOG );
 setup_adc( ADC_CLOCK_INTERNAL );
 // set_adc_channel( 2 );
 do {
 set_adc_channel( 1 );
 delay_ms(1);
 val1 = Read_ADC();
 lcd_gotoxy(1,1);
 printf(lcd_putc,"Red:%3u",val1);
 delay_ms(1);
 val2 = Read_ADC();
 lcd_gotoxy(9,1);
 printf(lcd_putc,"Blue:%3u",val2);
 set_adc_channel( 3 );
 delay_ms(1);
 val3 = Read_ADC();
 lcd_gotoxy(1,2);
 printf(lcd_putc,"Green:%3u",val3);
 Total=(float)(val1+val2+val3)*3/255;
 lcd_gotoxy(10,2);
 printf(lcd_putc," T:%4.2f",Total);
 } while (TRUE);
 I want to get 10 bit resolution conversion, but I just got 8 bit conversion, how to change it and get 10 bit conversion
		| valemike Guest
				|  Posted: Wed Jul 07, 2004 7:42 am |   |
				|  	  | Code: |  	  | #include <16F873.h>
 #device ADC=10
 #device *=16
 #use fast_io(A)
 #use fast_io(B)
 #use fast_io(C)
 The above is a snippet of code in my application that uses 10 bit A/D conversion.
 Notice the statement that says  #device ADC=10
 That's all you need to do.
		| BT Guest
				| 10-bit ADC |
				|  Posted: Wed Jul 07, 2004 7:46 am |   |
				| I always use the following in my #DEVICE statements: #DEVICE ADC=10
 But don't know what the default is if this is omitted .....
 HTH
		| young
				|  Posted: Wed Jul 07, 2004 7:55 am |   |
				| I added #device=10, but how to use the printf in my case
 printf(lcd_putc,"Red:%3u",val1) error occured format type is invalid.
		| valemike Guest
				|  Posted: Wed Jul 07, 2004 8:05 am |   |
				| I haven't done any LCD-printf() statements, but this is what I do to print my 16 bit values to Hyperterminal:
 printf("A/D value = 0x%lx\r\n", ad_value);
 similiarly, you can write: "AD = %ld\r\n", ad_value);
 where ad_value is a "long" (aka "int16"). The important thing to note is that you need the "l" (lower case L) after the % to denote that it is a "long".
		| young
				|  Posted: Wed Jul 07, 2004 8:07 am |   |
				| When I use         printf(lcd_putc,"G:%4x",val1);
 the out put  is 00fc, the high bits are 00 and lower bit are some value, it is not a ten bit value ( it is always lower than 255). what is wrong?
		| rnielsen
				|  Posted: Wed Jul 07, 2004 8:13 am |   |
				| You need to specify to print a LONG hex value.  A simple %4x will tell it to print an 8bit value.  Try this:
 printf(lcd_putc, "G:%lx", val1);
 That should enable you to print a 16bit value
 Ronald
 Smile, it will make people wonder what you've been up to.
		| young
				|  Posted: Wed Jul 07, 2004 8:24 am |   |
				| Thank you, NOw I am able to print out correct readings for val1, val2, and val3, however the calculation for T=(float)(val1+val2+val3)*3/1024 return wrong result as T sametime over 5.0, (should be lower than 3.0) what happened here? |  |
		| young
				|  Posted: Wed Jul 07, 2004 8:39 am |   |
				| Sorry, it is my misumderstanding, it is correct. since each of the val1, val2, val3 is less than 1024 than the (val1+val2+val3) less than 3*1024, then divided by 1024 should be less than 3, and 3*3 equals 9. |  |
		| Humberto
				|  Posted: Wed Jul 07, 2004 11:50 am |   |
				| BT wrote:
  	  | Quote: |  	  |
 #DEVICE ADC=10
 The default is ADC=8 , 2 LSB truncated.
 Humberto
 | You cannot post new topics in this forum You cannot reply to topics in this forum
