Printf output problem?
mvaraujo
PostPosted: Mon Jul 05, 2004 7:56 am     Reply with quote
Hi all,
I have something like this on my code:
printf(disp_store,"%03lu.%1uV    %02u.%1uHz",v_rms,v_rms_dec,freq,freq_dec);
It seams that sometimes it didn't output 16 characters but one less. Did you guys experience any problems like that on printf command?
Thanks!
Marcus
PostPosted: Mon Jul 05, 2004 11:47 am     Reply with quote
It seems that sometimes it didn't output 16 characters but one less
I made a test file and compiled it for the 16F877 with PCM vs. 3.188.
It works. I changed the printf statement to remove the output
to "disp_store", and instead I sent it to my terminal window.
I also added a 2nd line, which shows the character count.
Here are the results displayed in the terminal window:
012.3V    04.5Hz
1234567890123456
Here is the test program:
#include <16F877.h>
#use delay(clock = 4000000)
main()
int16 v_rms;
int8  v_rms_dec;
int8  freq;
int8  freq_dec;
v_rms = 12;
v_rms_dec = 3;
freq = 4;
freq_dec = 5;
printf("%03lu.%1uV    %02u.%1uHz",v_rms,v_rms_dec,freq,freq_dec);
printf("\n\r1234567890123456\n\r");
If this reply does not fix your problem then you should post
your own test program that demonstrates the problem, and
also give the PIC and the version of your compiler.
mvaraujo
PostPosted: Mon Jul 05, 2004 12:37 pm     Reply with quote
PCM programmer,
In fact I use this command and it works on the application. The point is that sometimes it sends other character less to the output. I still didn't find any correlation to interrupt services.
My question intends to know if any buggy behaviour in printf() is know by people!
Thanks!
Marcus
PostPosted: Mon Jul 05, 2004 7:57 pm     Reply with quote
the last one char will not be sent out if without the ... while(1); ... because CCS send PIC into sleep before the last one get out.
that's what happened to me years ago.
