carlosma
| two serial ports and two interrupts by fgetc() |
Posted: Fri Jun 25, 2004 11:19 am |
Hello
I have this problem.
For comunication betwen a PC and a mobil Modem I need two serial ports, for receive data of PC or Modem.
The hardware port work fine, but the software ports don't work, when use the fgetc(PORT_B).
How can i resolve this?
the interrupt:
#int_rda
void seirala_isr()
boolean Ea, Eb;
Ea=kbhit(COM_A);
Eb=kbhit(COM_B);
if (Ea)
cmd=fgetc(COM_A);
cmd=toupper(cmd);
fputc(cmd, COM_A);
Ea=0;
if (Eb)
dado_b=fgetc(COM_B);
dado_b=toupper(dado_b);
fputc(dado_b, COM_B);
Eb=0;
Carlos |
Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
Posted: Fri Jun 25, 2004 11:49 am |
| You can't use #int_rda for software serial, only hardware. Move your software serial RX to B0, B4-B7 or the CCP and you can use #int_ext, #int_rb or #int_ccp respectively. |
carlosma
Posted: Mon Jun 28, 2004 4:51 am |
Ok I change to RB0 but now I have a error caracter when fputc()
I have now the program:
#include <16F877.h>
#fuses HS,NOPROTECT,NOWDT,NOLVP,PUT,NOBROWNOUT
#use delay(clock=16000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, STREAM=COM_A)
#USE RS232(BAUD=9600, XMIT=PIN_B1, RCV=PIN_B0, STREAM=COM_B)
#int_ext //interrupt for sotftware COM_B USART port
void vira()
fputc(dado_b,COM_B);
#int_rda //interrupt for hardware COM_A USART port
void seirala_isr()
cmd=fgetc(COM_A);
cmd=toupper(cmd);
fputc(cmd, COM_A);
#int_timer0 //interrupt for real time clock
timer0_isr()
clock-=256; // 256 > dois elevado a 8
if(clock<256)
clock+=CLOCK_VAL;
tick=1;
seconds++;
void init_chip()
setup_adc_ports(No_Analogs);
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_32);
enable_interrupts(int_timer0); // Enable timer0 interrupt
enable_interrupts(INT_RDA);
enable_interrupts(int_ext);
static boolean led2;
init_ext_eeprom();
init_chip();
fprintf(COM_A,"\r\nRead or Write: ");
if (tick) // real time clock 1 second
tick=0;
update_clock();
led2 = !led2; // led flash 1 second
output_bit (pin_c0,led2);
if(dado_b=='A')
fprintf(COM_A,"Tunga........->");
if(cmd=='R')
read_eeprom_string(s, ROM_SMTP, ROM_SMTP_SIZE);
fprintf(COM_B,"AT#ESMTP=\"%s\"\r\n",s);
| [/quote] |
steve.booth
Posted: Fri Feb 11, 2005 2:18 am |
I would suggest that you don't use fputc within your interrupt routines.
ISR's should be kept as short as possible, and a 'put' take a comparable long time to execute.
Use the interrupt routine to set a flag and then detect the flag in your MAIN. _________________ Steve |
Mark
Posted: Fri Feb 11, 2005 7:10 am |
| You do realize that you are respoding to a post from June of last year! |
