Will Reeve
Joined: 30 Oct 2003 Posts: 209 Location: Norfolk, England
| Soldering down PLCC PICs |
Posted: Sat Jun 26, 2004 10:08 am |
Is it regarded good practice to solder down PLCC PIC’s? I was planning to use the TQFP package but they are considerably more expensive that the PLCC package. I’ve only used them in sockets before but this design is on a budget!
Will |
rnielsen
Posted: Sun Jun 27, 2004 12:07 am |
If the PIC will be installed permanently, then sure. It will make upgrading the software more dificult, unless you are going to do in-circuit programming. The only reason you want to 'socket' the PIC is for upgrades or proto-typing. Soldering is definately more reliable, in my opinion.
Ronald |
MikeW
Joined: 15 Sep 2003 Posts: 185 Location: Warrington UK
Posted: Sun Jun 27, 2004 1:27 am |
PLCC is fine if you are having the boards made by a professional company.
I assume that the rest of the components are also smd, so the boards will be manufactured using pick and place machines, and soldered by machines as well.
Hand soldering PLCC packages is not suitable, since the contact between board and pin is underneath the plastic.
I have soldered PLCC for a prototype, but it is hit and miss
Mike |
Will Reeve
Posted: Sun Jun 27, 2004 1:05 pm |
| PLCC it is then. At over 1UKP cheaper than the TQFP part! But why do Microchip have such a "random" policy of pin numbering, they could at least keep the numbers the same between the 44pin packages! |
rnielsen
Posted: Sun Jun 27, 2004 9:40 pm |
There are some standard packages that have been established but not all of the IC's that are designed have the same count I/O. They simply select the packages that they want to incorporate in their product and then do the best with what has been laid out.
Ronald |
jventerprises
| soldering PLCCs |
Posted: Mon Jun 28, 2004 10:16 am |
i solder the PLCCs reliably all the time (for customers), BUT i have a 10x optical scope to do it AND a Metcal iron with an appropriate tip. still, it takes some time and is easy to short adjacent pins.
buy the TQFP and save yourself time and annoyance! _________________ Jon |
SherpaDoug
Posted: Mon Jun 28, 2004 11:02 am |
I have hand soldered 44pin PLCC packages for years for US Navy and other marine customers without any problems. I even remove and replace chips. Just keep things clean, hot (750), and fast. I use a common Weller WES50 iron with a fine flat tip. I use a glass for inspection afterward. Soldering using a glass is a pain due to bad depth perception. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Kasper
Joined: 14 Jan 2004 Posts: 88 Location: Aurora, Ontario, Canada
Posted: Mon Jun 28, 2004 12:20 pm |
Solder braid is your friend for doing fine pitch soldering. I often solder on chips with down to 0.5mm pitch by hand using a regular weller iron. shorts all over, then clean up with solder braid, mop up the left over flux and it looks machine done for inspecting for shorts, magnification and holding up the board against a light source and you can see even the smallest shorts. |
SteveS
Posted: Mon Jun 28, 2004 12:39 pm |
| Quote: |
- And I thought I was the only one doing that (well maybe not the machine done look) We have an assembler that does even the real fine pitch all by hand and it's beautiful. I normally stop at 0805 and SOIC parts and let him take over. |
jventerprises
| solder braid |
Posted: Mon Jun 28, 2004 12:55 pm |
i agree with the solder braid trick. just solder away and clean it up afterwards with the braid. i do that too. just be careful not to over heat the part. its real easy to do with braid. you can damage some of the smaller parts by applying too much heat.
solder braid does leave a lot of flux residue, so you might want to clean the boards after..... _________________ Jon |
SherpaDoug
Posted: Mon Jun 28, 2004 2:06 pm |
The Pace video shows soldering one pin at a time in sucession with an iron. I prefer to solder every other or every third pin first, and come back for the others on later passes. My theory is that it reduces the thermal stress. Like tightening the lug bolts on a wheel it is better to apply the stress evenly than to completely stress one area and then an adjacent area. You can end up with one side of the chip very hot while the others are still cool.
Just my gut feel. _________________ The search for better is endless. Instead simply find very good and get the job done. |
