MCP_USB programmer with CCS C?
falleaf
PostPosted: Sun Jun 20, 2004 12:49 am     Reply with quote
I'm using MCP_USB programmer of Olimex. I used to play with it in MPLAB with no problem. However, as writing CCS C and compile to Hex files. I open MPLAB to import the .Hex files program to the chip. However, a warns is: hex file cannot be read or writen because its extension is not recognized
May some one help me on this?
Thanks indeed
kypec
PostPosted: Sun Jun 20, 2004 11:39 pm     Reply with quote
You may try to run this batch file:
C:\Program Files\MPLAB IDE\dlls\register.bat
provided that you have MPLAB installed in the default directory.
It should fix the DLL registration problem which you are describing.
Good luck,
kypec
falleaf
PostPosted: Mon Jun 21, 2004 4:01 pm     Reply with quote
Thanks K, I fixed the problems
May you explain me why it's so? thanks indeed
kypec
PostPosted: Mon Jun 21, 2004 11:20 pm     Reply with quote
This problem is caused by unwanted unregistration of some DLL libraries
of MPLAB. Do not ask me how this can happen Confused
It also happened to me once or twice and I'm using MPLAB IDE v6.xx since its first version was released which is I think more than 18 months now.
If you want to know how I figured out what is the problem and how to solve it then here is the answer -> I'm regularly checking also the Microchip discussion forum on MPLAB Wink
glad to hear you fixed it Razz
kypec
falleaf
PostPosted: Tue Jun 22, 2004 1:28 am     Reply with quote
Thanks for all kypec
