hundil Guest
POWER-UP PROBLEM |
Posted: Mon Jun 07, 2004 7:44 am |
hiiiii
I HAVE A MODERATE SIZE BOARD USING PIC16F877.
I USE A FEW DIFFERENT INTERRUPTS IN THE SOFTWARE.
(BUT, IT IS THE SAME IF I USE PROGRAMS WITHOUT INTERRUPTS)
I USE CCS COMPILER WITH THE VERSION
WHEN THE CIRCUIT IS POWERED-UP FOR THE FIRST TIME AFTER PIC IS PROGRAMMED, EVERY THING
IS OK. IF IT IS POWERED DOWN AND POWERED-UP AGAIN, IT IS NEVER WORKING ANYMORE.
WHAT MAY THE REASON BE ?
IF IT IS TURNED ON BY AC PLUG SWITCH, IT IS NOT WORKING
BUT, IF APPLIED DC POWER SOURCE BY A CONNECTOR DIRECTLY, IT IS ALMOST OK.
ADDITIONALLY, IF I PUT THE BOARD ON A CLEAR PAPER SHEET NORMALLY, I CAN NOT SEE ANY CHARACTER
ON LCD. (EXCEPT A DARKED FIRST LINE)
BUT IF I PUT THE BOARD WITH PIC16F877 VERTICALLY (!) , IT IS WORKING PROPERLY.
WHAT DO YOU THINK THE PROBLEM IS?
IS THAT MATTER JUST FOR PIC MICROCONTROLLERS?
WHAT SHOULD I DO?
THANKS...
hundil |
hundil Guest
power-up problem again |
Posted: Mon Jun 07, 2004 7:56 am |
There is a 100n capacitor connected to the out pin of 7805 regulator, even
it (100n) is very near to VDD and VSS pins of PIC16F877.
HELP........... |
rnielsen
Posted: Mon Jun 07, 2004 8:32 am |
First, make sure you have MCLR tied to VCC through a resistor. Next, if you are not doing any in-circuit programming make sure you have NOLVP in your #fuses statement. This one bit me for a while until I learned about it. |
future
Posted: Mon Jun 07, 2004 8:42 am |
Try adding #zero_ram directive |
Posted: Mon Jun 07, 2004 8:52 am |
rnielsen wrote: | First, make sure you have MCLR tied to VCC through a resistor. Next, if you are not doing any in-circuit programming make sure you have NOLVP in your #fuses statement. This one bit me for a while until I learned about it. |
Also make sure that both ground, and both power connections are made. The faults described are fairly typical on chips where only one has been used.
What input capacitor is used on the regulator?. The input capacitor is also vital for stability if there is any significant lead length from the input filter.
A single 0.1uF, is pretty minimal if the processor is doing much. Look at having a single cap as close to the regulator as possble, and another close to each logic device.
