Picdem 2 Plus LCD Driver
zogbog
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Wed Jun 02, 2004 5:10 am     Reply with quote
I am new to writing code but i have been involved in debugging other peoples code for some time. I need an lcd driver for the picdem 2 plus board. I have tryed some of the posted examples but i am not yet up to speed and i don't think i am editing the correctly etc. if anyone has a full lcd driver that works well please could they email it to me or provide any help to get me started. I have used the ccs lcd.c driver before and it worked on other boards but not the Picdem 2. all i need is to change the ports and i can get on with learning how to program pics.
Any help is great
Mad
treitmey
PostPosted: Wed Jun 02, 2004 7:45 am     Reply with quote
here is what I came up with. I just made some mods to other dirvers.
drop it in the drivers subdirectory and include it in the *.h files
////                 PICDEM2_LCD.C                                 ////
////                 Driver for common PICDEM2 PLUS LCD modules        ////
////  lcd_init()   Must be called before any other function.           ////
////  lcd_putc(c)  Will display c on the next position of the LCD.     ////
////                     The following have special meaning:           ////
////                      \f  Clear display                            ////
////                      \n  Go to start of second line               ////
////                      \b  Move back one position                   ////
////  lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1)    ////
////  lcd_getc(x,y)   Returns character at position x,y on LCD         ////
#define use_PICDEM2_lcd TRUE
#if defined use_PICDEM2_lcd
   #define  lcd_en  PIN_A1
   #define  lcd_rw  PIN_A2
   #define  lcd_rs  PIN_A3
   #define  lcd_type 2           // 0=5x7, 1=5x10, 2=2 lines
   #define  lcd_line_two 0x40    // LCD RAM address for the second line
   #define  d_cycle 1
void lcd_send_nibble( BYTE n ) {
   n=n&0x0f; //Strip off the top 4 bits.. This only sends bit 3:0
   output_d(n);
   delay_cycles(d_cycle);
   output_high(lcd_en);
   delay_us(20);
   output_low(lcd_en);
BYTE lcd_read_byte() {
   BYTE low,high;
   output_high(lcd_rw);
   high = input_d(); //using d0:d3 for 4 bit data bus
   output_low(lcd_en);
   delay_us(1);
   low = input_d(); //using d0:d3 for 4 bit data bus
   output_low(lcd_en);
   return((high<<4) | low);
void lcd_send_byte( BYTE A0, BYTE n ) {    //A0:  0=instruction, 1=Data
   output_low(lcd_rs);
   while ( bit_test(lcd_read_byte(),7) ) ; // wait until busy flag is low
   if (A0==0){ output_low(lcd_rs);} //0=Instruction  and 1=Data
   if (A0==1){output_high(lcd_rs);} //0=Instruction  and 1=Data
   output_low(lcd_rw);
   output_low(lcd_en);
   lcd_send_nibble(n >> 4);
   lcd_send_nibble(n & 0xf);
void lcd_init() {
   BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
   // These bytes need to be sent to the LCD for initialization.
   BYTE i;
   //fprintf(debug,"Init!!\n\r");
   output_low(lcd_rs);
   output_low(lcd_rw);
   output_low(lcd_en);
   delay_ms(15);
   for(i=1;i<=3;++i) {
      lcd_send_nibble(3);
      delay_ms(5);
   lcd_send_nibble(2);
   for(i=0;i<=3;++i){
      lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
   BYTE Data;
   if(y!=1)
      Data=lcd_line_two;
      Data=0;
   Data+=x-1;
   lcd_send_byte(0,0x80|Data);
void lcd_putc( char c) {
   switch (c) {
      case '\f'   :
         lcd_send_byte(0,1);
         delay_ms(2);
      case '\n'   :
         lcd_gotoxy(1,2);
      case '\b'   :
         lcd_send_byte(0,0x10);
      default     :
         lcd_send_byte(1,c);
char lcd_getc( BYTE x, BYTE y) {
   char value;
   lcd_gotoxy(x,y);
   while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
   value = lcd_read_byte();
   output_low(lcd_rs);
   return(value);
