Question about malloc() and PIC18F6621
Hans Wedemeyer
PostPosted: Sun May 30, 2004 7:58 pm     Reply with quote
malloc() fails to allocate 556 bytes.
The PIC18F6621 has 3840 byte of SRAM.
The project LST file shows plenty of memory available:
RAM used: 1039 (27%) at main() level
1214 (32%) worst case
I think I'm setting up correctly for using Malloc(0
From the project header file:
#include <18F6621.h>
#device *=16, adc=8
#pragma USE DYNAMIC_MEMORY
#include <STDLIBM.H>
In the help file for Malloc() the size parameter is stated to be an Integer !
Does anyone know if malloc is really limited to 255 bytes ?
from help file:
Parameters:
size is an integer representing the number of bytes to be allocated.
Reply from CCS tech support....
PostPosted: Tue Jun 01, 2004 5:08 pm     Reply with quote
Change size_t variable in stddef.h to a long instead of an int. The malloc function uses the size_t variable to determine the return type.
CCS Tech Support
