Hans Wedemeyer
| Version 3.19 compared to V3.201 |
Posted: Wed May 26, 2004 9:55 pm |
If V3.201 can optimize the same source and reduce the output by about 4000 bytes! that would be great... if the code still works. !
I think something is wrong somewhere.... !
I never noticed the math error in LST file for V3.190 until tonight.
LST file for same source file:
CCS PCH C Compiler, Version 3.190, 21503
ROM used: 26168 (82%)
Largest free fragment is 26168
RAM used: 1253 (82%) at main() level
1338 (88%) worst case
Stack: 7 worst case (6 in main + 1 for interrupts)
CCS PCH C Compiler, Version 3.201, 21503
ROM used: 22118 bytes (69%)
Largest free fragment is 9814
Stack: 7 worst case (6 in main + 1 for interrupts) |
C-H Wu Guest
| expect a 3.202 on Friday |
Posted: Thu May 27, 2004 2:35 am |
A code size reduction of 12% with #opt10 since 3.187 is typical.
However, read this:
3.201 New infrastructure added in 3.200 to support new chips and families has
3.201 caused a large number of problems, The reported problems are fixed in 3.201
3.201 Use with caution, expect a 3.202 on Friday. 3.191 is stable.
with great caution, I just download 3.191 again and found that the delay_us() is still there !
3.187 is better for me because it does not the BSR setting bug in 3.188 ~ 3.200, nor the sint32 relational comparison bug in 3.190, nor the delay_us() bug in 3.191 ~ 3.200.
I am not going to beta test the 3.201 or 3.202 on weekend.
Best wishes |
| Re: expect a 3.202 on Friday |
Posted: Thu May 27, 2004 6:55 am |
| C-H Wu wrote: | A code size reduction of 12% with #opt10 since 3.187 is typical.
Best wishes |
Yes I read that warning and only downloaded just to see what it did with the bugs I had reported earlier.
That fact that CCS even issued a warning is a step in the right direction !
I never switch on optimization unless I'm running into a code size problem. So about 4000 byte redution with no Opt. is a lot !
Hans W |
C-H Wu Guest
Posted: Thu May 27, 2004 7:16 am |
| Anonymous wrote: | | C-H Wu wrote: | A code size reduction of 12% with #opt10 since 3.187 is typical.
Best wishes |
Hans W |
>> with no Opt.
no no, the default optimization level for PCW is 9, i.e. same as #opt 9, which is the same as #opt 10 for 3.188 ~ 3.191. If you really want safety, you should set it back to #opt 5 or #opt 7, which will bring you back to the old days.
C-H Wu |
