Problem with struct pointer, cannot access character array
Franco
PostPosted: Wed May 26, 2004 12:32 am     Reply with quote
I have definded the following struct and a pointer to this struct:
struct mystruct {
  int myfirstint;
  char myarray[10];
  int mylastint;
} thisismystruct;
struct mystruct *mystructPtr;
Now I point the struct pointer to this struct and I want to access the struct elements using the struct pointer operator -> :
mystructPtr = &thisismystruct;
mystructPtr->myfirstint;             // works fine, returns the correct value
mystructPtr->myarray[0];             // does not work, returns wrong value
mystructPtr->myarray[5];             // does not work, returns wrong value
mystructPtr->mylastint;              // works fine, returns the correct value
This works fine for the integers, but if I want to access the elements of the character array, I get completely wrong values. I had a look at the generated assembler code, and it looks wrong for the character array, because it seems to simple.
Does anyone out there have an idea?
Cheers Franco
PostPosted: Wed May 26, 2004 10:32 am     Reply with quote
I made a test program, to check your problem.
It works fine with a 16F877, and PCM vs. 3.188.
The output on my terminal window is: A05B
#include <16F877.h>
#use delay(clock = 4000000)
struct mystruct {
  int myfirstint;
  char myarray[10];
  int mylastint;
} thisismystruct;
char c;
char i;
// Initialize the structure.
thisismystruct.myfirstint = 'A';
// Fill the array with ASCII chars '0' to '9'.
for(i = 0; i < 10; i++)
    thisismystruct.myarray[i] = i + '0';
thisismystruct.mylastint = 'B';
// Display some elements of the structure.
c = mystructPtr->myfirstint;
putc(c);
c = mystructPtr->myarray[0];
putc(c);
c = mystructPtr->myarray[5];
putc(c);
c = mystructPtr->mylastint;
putc(c);
