Posted: Tue May 25, 2004 10:02 am |
The problem is:
int var = 10;
float resul;
resul = (float)var;
and i get resul =.166e-41
either ice2000 and icd2.
Why?
I always have the problems with ice2000 about the return of read _adc() that is wrong. |
Posted: Tue May 25, 2004 10:09 am |
Haplo wrote: | Did you try the setup_adc(ADC_CLOCK_DIV_32); ?
As others have pointed to you, according to the datasheet, the ADC clock should be set so it would guarantee a minimum of 19.2us for the conversion to complete. Your current setting is giving it less than 4us.
And also, what is the impedance on your analog pin? According to the datasheet, The maximum recommended impedance for analog sources is 10 kΩ. |
Hi Haplo,
1. I tried the setup_adc(ADC_CLOCK_DIV_32) already.
2. I input the analog value from a DC power supply directly, it's variable.
Thanks and Best Regards. |
xinyh
Posted: Tue May 25, 2004 9:46 pm |
Hi Ttelmah, Haplo and all,
It's working now. What I did is as below:
1. Rebuilt the project by PIC wizard;
2. Define value as "Long int value";
3. float = (float)value*(5.0/1024.0); don't use value*(5/1024).
Thanks for your valuable guidance.
Best Regards,
Xinyh |
Tony Guest
adc |
Posted: Wed May 26, 2004 2:39 am |
i'm following the suggestion but it doesn't work.
The code is :
#include <18F452.h>
#DEVICE ICD=TRUE
#DEVICE ADC=10
#include <MATH.H>
#USE FAST_IO(A)
#FUSES HS, NOPROTECT, NOPUT, NOBROWNOUT, NOWDT, NOCPD #USE DELAY (CLOCK=8000000)
#ZERO_RAM
long int value;
float result;
/* Configuration for A/D */
setup_port_a(ALL_ANALOG);
setup_adc_ports(ALL_ANALOG);
/* Port A.0 in input */
set_tris_A(0x01);
set_adc_channel(0);
delay_us(10);
/* Read the value by A/D internal of PIC18F452 */
value = read_adc();
/* Calculate result in floating point */
result = (float)value*(5.0/1024.0);
I'm working by MPLAB 6.40 & CCS 3.177.
Vdd = 3V; VinA/D = 0.756V;
ICE2000 : value = 156 (W R O N G!!!!!)
ICD2 : value = 263 (C O R R E C T)
Why this difference?
Either ICE2000 and ICD2 i get result = .599969e-41 instead of 1.284.
Anyone can i help me???
It's IMPORTANT & URGENT!!!!!
Tony
rwyoung
Re: adc |
Posted: Wed May 26, 2004 7:35 am |
Tony wrote: |
Change this line and try:
result = (float)value * 0.0048828125;
What you are getting looks like it might be an underflow or a bug in 3.177's floating point routines. The above line pre-calculates the 5/1024 and uses just a multiply.
As for your ICE2000 giving a different results from the ADC, I'm not suprised at that. I've seen other ICE's give wrong values back from perpherals like ADCs and pulse-capture. _________________ Rob Young
tony Guest
adc |
Posted: Wed May 26, 2004 8:20 am |
Thanks, so what do you suggest?
I have to buy CCS 3.190? |
rwyoung
Posted: Wed May 26, 2004 12:37 pm |
Did the 0.0488 multiply work for you?
As a mater of personal preference, I avoid the division operator no mater what processor or compiler I'm using. _________________ Rob Young
ingemilo
Posted: Tue Apr 19, 2016 7:44 pm |
printf("\n\r ADC-value: %4X \r\n", value);
Here you will get an hexadecimal number
Why don't change as below
printf("\n\r ADC-value: %4Ld \r\n", value); |
ingemilo
Re: adc |
Posted: Tue Apr 19, 2016 8:00 pm |
Tony wrote: | Hi,
The code is :
#include <18F452.h>
#DEVICE ICD=TRUE
#DEVICE ADC=10
#include <MATH.H>
#USE FAST_IO(A)
#ZERO_RAM
long int value;
float result;
set_tris_A(0x01);
set_adc_channel(0);
delay_us(10);
value = read_adc();
Tony
Because Vdd = 3V you must use
result = (float)value*(3.0/1024.0);
instead
result = (float)value*(5.0/1024.0); |
Joined: 01 Jul 2010 Posts: 9107 Location: Greensville,Ontario
Posted: Wed Apr 20, 2016 5:19 am |
Hang on... you've got a worse problem !!
According to your program....PIC is 18F452, VDD is 3 volts...
The PIC18F452 is NOT rated to have a VDD of 3 volts!! Check out figure 22-1 of the datasheet. Yes, some individual PICs seem to work OK with an out of spec VDD but they will give random or odd results, quirky performance or just 'die' for some unknown reason.
Check the electrical specs, figure 22-1 in the datasheet. This is important!
You have 2 options
1) buy the 'L' version of the PIC. it IS rated for 3 volt operation,but read the datasheet-do the math, it will NOT run at 40MHz at 3V, more like 12MHz.
2) Use a VDD of 5 volts. The 18F452 WILL work fine then,at full speed of 40 MHz !!
ezflyr
Posted: Wed Apr 20, 2016 7:12 am |
You guys (ingemilo & temtronic) do realize that you are posting on a twelve year old "zombie" thread, right??????? _________________ John
If it's worth doing, it's worth doing in real hardware! |
