Richard Guest
| dividing |
Posted: Mon May 24, 2004 5:35 am |
Dear Friends
I want to code an alogorithm to detect multiples of say 8 from a variable
i.e
8/8 =1 it has occured once
9/8=1.125
10/8=1.25
etc.......
etc.....
16/8 = it has occured twice
Can anyone tell me how I would detect if there was no remainder
i.e an exact multiple of 8.
Can you please give me an example!! |
.C
Posted: Mon May 24, 2004 6:24 am |
try this:
#define true 1
int Test;
short int multiple;
Test =64;
if ( ! (Test % 8) ) multiple=true; |
| Re: dividing |
Posted: Mon May 24, 2004 6:26 am |
| Richard wrote: | Dear Friends
i.e
9/8=1.125
10/8=1.25
etc.......
etc.....
The modulus function.
if ((val%8) == 0) //do what you want here.
Alternatively (quicker if your test is for '8', rather than any number), use the bitwise and, with:
if ((val & 7) == 0) //operations here.
The '%', returns the remainder from dividing the first number by the second.
The second route, takes advantage of the fact that numbers are stored in binary, so:
8 = 0001000
9 = 0001001
16 = 0010000
17 = 0010001
If you 'AND' these numbers with 7, you get:
8 & 7 = 0
9 & 7 = 1
16 & 7 = 0
17 & 7 = 1
etc.
The result will only be 'zero', when the number is an exact multiple of 8.
Birdie Guest
Posted: Mon May 24, 2004 7:00 am |
There is another option that gives all the information regarding the result of the test, both quotient and remainder (if you need it):
ldiv_t test;
signed long test_value;
long times_occurred;
test_value = 64;
test = ldiv(test_value,8);
if(test.rem == 0)
times_occurred = test.quot;
This ldiv function is also good for shrinking code size when using printf() with a float value. As a substitute:
ldiv_t tempory;
float PrintValue;
PrintValue = 347.8;
PrintValue *= 10;
tempory = ldiv((signed long)PrintValue,10);
printf(lcd_putc,"%ld.%1ld",tempory.quot,tempory.rem); |
