Multiplications
.C
Multiplications
PostPosted: Sun May 23, 2004 2:40 am     Reply with quote
PIC18 family:
If I write a=b*c , Does the compiler use hardware multiplication?
Or I have to use a special 'C' istruction or built-in functions?
Thank
C-H Wu
PostPosted: Sun May 23, 2004 2:56 am     Reply with quote
It depends on the data type, here's my test report with PCH 3.200
// computation speed:     ( usec )    16F877      18F452    Wu
// ----- int8    * int8                10           1
// ----- int16   * int16               48           7        9
// ----- s_int16 * s_int16             50           7        9
//   . . with saturation routine       --          --       21
// ----- s_int32 * s_int32            127          45
// ----- float   + float               --          37 !
// ----- float   * float              136         136 !     52 (1e-7)
// ----- float   / float              277         277      287 (1e-7)
//                                                         200 (1e-5)
It seems that they still don't like the hardware multiplier for float multiplication, and my own float_mult() routine is still three times faster.
.C
PostPosted: Mon May 24, 2004 2:31 am     Reply with quote
In the my code I wrote :
long A;
int b;
A=B*.800;
but I have not seen in the dissassemby listing multiplications hardware
Haplo
PostPosted: Mon May 24, 2004 3:23 am     Reply with quote
Remember the hardware multiplier works only on 8-bit and 16-bit isgned/unsigned integers, not floats.
PostPosted: Mon May 24, 2004 4:50 am     Reply with quote
This does not matter.
All the multiplication is 'built up' from operations on smaller types. So the hardware function, can be used as one of the 'building blocks' to create the higher operation types. At present, CCS do not use this (basically, they have not re-written their own 'library' to take advantage of the ability) for floats. They have done for integers. This is why the 32*32 multiplication, has gained from the function, despite the function not handling this type. The function can be very effectively used to help when dealing with floats, but it requires the maths routine to be re-written to do so. Basically, since the chip iself (on versions without the hardware multiplier), only deals with 8bit values, and the 16bit and higher routines on these chips is built from the functions using the 8bit type, CCS elected to write the floating point routine to use only the 8bit operations. On chips with the hardware multiplier however there is a saving from using 16bit arithmetic routines (so for instance, a 16*16 multiply, only takes 7usec on the table published by C-H Wu, when a 8*8 multiply takes 10uSec, and building the 16*16 multiply using the 8*8 multiply, takes 48uSec.
On some other compilers, the hardware multiplier is used for floating point arithmetic, and the time taken for a floating point multiplication, typically halves.
Haplo
PostPosted: Mon May 24, 2004 5:45 am     Reply with quote
That is basically what I was trying to say Very Happy
