asjad
Joined: 09 Mar 2004 Posts: 52 Location: Greater Manchester - UK
3pin resonator |
Posted: Sun May 23, 2004 12:55 pm |
Dear all,
I have recently bought a 3pin ceramic resonator (built in capacitors)
Can I assume that the outer 2 pins are for the PIC and the centre for ground.
Any sugestions
I need help it seems that when I program the PIC16F874 and press reset it takes about 10seconds for the program to start and even then it works slower than I expect it too, all coding is correct.
Could it be incorrect connection of the 3pin resonator??? _________________ Best Regards |
davidpk
Posted: Sun May 23, 2004 1:05 pm |
A manufacturer and part number for your part would help. (The resonator, not the PIC ) |
rwyoung
Posted: Sun May 23, 2004 1:10 pm |
Typically the outer two pins connect to the xtal1 and xtal2 pins of the PIC and the center pin is ground.
If you can find a datasheet for the part, check the capacitance values, they may not be high enough or they may be too high. Also if the ground pin is unconnected or poorly connected (high impedance) it could exhibit the problems you describe.
Also set your fuses correctly, XT for up to 4MHz and HS for higher speeds.
I also like to use the Power Up Timer fuse on all my projects. _________________ Rob Young
asjad
Gabriel Caffese
Joined: 09 Oct 2003 Posts: 39 Location: LA PLATA, ARGENTINA
Posted: Sun May 23, 2004 2:27 pm |
One of major 2 or 3 pin resonator manufacturer is MURATA.
They are usually blue, so, they donīt seem to be MURATA.
Apart from this, arenīt you paying too much for a resonator ?
The prices I see in this page are nearly same price as cristals -wich are far more accurate-
Gabriel.- |
davidpk
Posted: Sun May 23, 2004 3:14 pm |
All of the data sheets I've just browsed for these parts show the connections exactly as you have done. None of the data indicate that this would work, but I would try it in a pinch, swap the OSC1 and OSC2 pins. It shouldn't make a difference but there's always things not shown on data sheets that the manufacturer assumes. |
rwyoung
Re: resonator manufacturer |
Posted: Sun May 23, 2004 7:39 pm |
Looks like ones I've bought through Digikey and they were from ECS International. Perhaps their ZTT line. Typical capacitance value of 30pF.
As I mentioned before, make sure you have the right Fuses picked for your oscillator speed, example 4.0MHz use XT fuse, 16.0MHz use HS fuse... _________________ Rob Young
dyeatman
Resonators |
Posted: Sun May 23, 2004 7:42 pm |
Yes, it appears they are the ECS resonators (i have a bunch of them stored away, I use can oscillators now) with the same markings and yes the two outside pins are the XTAL inputs with the center ground. |
rwyoung
Posted: Mon May 24, 2004 7:40 am |
asjad -
Is this related to the lcd & rtc code you are posting about?
I mentioned in that post to use an oscilloscope and x10 probe to check that the oscillator is running and also to watch an output pin toggle once each interrupt (modify your interrupt code of course). _________________ Rob Young
