HOLTEK (HT6026 Encoder) + PIC
thiaguetz
PostPosted: Tue May 18, 2004 2:18 pm     Reply with quote
hi,
I am building a little circuit that control my home garage gate and my office gate using PIC.
But the decoder, on the gate system, use the Holtek HT6026 encoder as the emitter of the open and close signal.
So, the question is... the control, that comes with the garage kit, use two types of logic.. (zero or open)... when there is no jumper on the logic pin, the encoder send as "open".. but when there is a jumper on tem logic pin, the signal is zero (ground).
The point is... i can emulate the ground sigal using a PNP transistor... to switch the logic... BUT, how can i simulate a "open" logic pin?
For reference, the HT6026 datasheet http://www.holtek.com.tw/pdf/consumer/6026.pdf
thanks!
rnielsen
PostPosted: Tue May 18, 2004 3:29 pm     Reply with quote
How about output_float()?
From the CCS help file: Sets the specified pin to the input mode. This will allow the pin to float high to represent a high on an open collector type of connection.
Ronald
thiaguetz
PostPosted: Thu May 20, 2004 8:53 am     Reply with quote
Thanks dood!
I will test it.
thanks!
