Problem with character position on an LCD
RatFink
PostPosted: Wed May 19, 2004 2:36 am     Reply with quote
Well, after finally getting my LCD to work, I found another small problem, here's the code.
   while (T0IF == 0); /* Stay in loop until T0IF sets */
   lcd_gotoxy(0,2);
   lcd_putc("TEMP");
   /* Exit loop */
   T0IF = 0;   /* Clear the T0IF flag */
   GO = 1;   /* Start A/D conversion */
   do
   while (ADIF == 0 );    /* Wait for conversion to complete */
   HEAT = ADRESH*(5.0/255)*100;      /* Load HEAT with A/D value converted to volts, then degrees*/
   lcd_gotoxy(5,2);
   printf(lcd_putc, "%d", HEAT);
I want to print the word "TEMP" at the first position on line 2, and the the value in "HEAT" at the 6th position of line 2 but for some reason The second value just keeps printing over the word TEMP. If I try it on line 1 it works fine.
I've looked though the driver I'm using but I just can't seem to find anything wrong. Here's the driver I'm using.
////////////////////   LCD   //////////////////////////////
// As defined in the following structure the pin connection is as follows:
//     A1  enable
//     A2  rw
//     A3  rs
//     D0  D4
//     D1  D5
//     D2  D6
//     D3  D7
//   LCD pins D0-D3 are not used and PIC D3 is not used.
#if defined(__PCH__)
   #byte lcd = 0xF83      // This puts the entire structure
#else
   #byte lcd = 8          // on to port D (at address 8)
#define lcd_type 2           // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40    // LCD RAM address for the second line
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
                            // These bytes need to be sent to the LCD
                            // to start it up.
                     // for 2 lines lcd: {0x0a,0xc,1,6}
                     // for 5x10 lcd:   {0x06,0xc,1,6}
                     // for 5x7 lcd:      {0x20,0xc,1,6}
                             // The following are used for setting
                             // the I/O port direction register.
//***** lcd command port  *******************************************************************
struct lcd_command{
   char none:1;
   char enable:1;
   char read_write:1;//rw
   char data_command:1;//rs
struct lcd_command lcd_command_port;
#locate lcd_command_port=5
struct lcd_data{
   char data:4;
struct lcd_data lcd_data_port;
#locate lcd_data_port=8
//************  "COMMAND / DATA definition  ************************************************************
#define COMMAND0 0
#define DATA1 1
//************  "READ / WRITE definition  ************************************************************
#define WRITE0 0   //LCD <- MPU
#define READ1 1  //LCD -> MPU
//************  "E_UP / E_DOWN definition  ************************************************************
#define E_DOWN 0
#define E_UP 1
//**********eeprom or flash******************************************************************************
#define EEPROM0 0   ;eeprom - not the program  memory
#define FLASH1 1   ;program memory
//*********  set tris d  *********************************************************************
#define set_tris_lcd_read(){\
   set_tris_a(TRISA & 0xf1/*0b11110001*/);\
   set_tris_d(TRISD | 0x0f/*0b00001111*/);\
#define set_tris_lcd_write(){\
   set_tris_d(TRISD & 0xf0/*0b11110000*/);\
//***********   clear LCD  ************************************
#define clear_lcd   lcd_send_byte(0x1,COMMAND0);//clear lcd display
char lcd_read_byte(void){
      char low,high;
      set_tris_lcd_read();
      lcd_command_port.read_write = READ1;
      delay_cycles(1);
      lcd_command_port.enable = E_UP;
      delay_cycles(1);
      high = lcd_data_port.data & 0x0f;
      lcd_command_port.enable = E_DOWN;
      delay_cycles(1);
      delay_us(1);
      low = lcd_data_port.data & 0x0f;
      set_tris_lcd_write();
      return( (high << 4) | low);
void lcd_write_nibble(char temp_wr){
//Purpose:
      lcd_data_port.data = temp_wr;
      delay_cycles(1);
      lcd_command_port.enable = 1;
      delay_us(2);
      lcd_command_port.enable = 0;
void lcd_send_byte(char data , char data_or_command ) {
      lcd_command_port.data_command = COMMAND0;
      while ( bit_test(lcd_read_byte(),7) ) ;
      lcd_command_port.data_command = data_or_command;
      delay_cycles(1);
      lcd_command_port.read_write = WRITE0;
      delay_cycles(1);
      lcd_write_nibble(data >> 4);
      lcd_write_nibble(data & 0xf);
void lcd_gotoxy( char location, char line) {//location 0...
   char address;
   if(line!=1)
     address=40;//was80
     address=0;
   address+=location;
   lcd_send_byte(0x80|address,COMMAND0);
//********** -  1 - **************************************************
void lcd_init(void){
//Purpose: initiate the lcd
   //turnning PORTA0=analog, PORTA1-7=digital
   ADCON1=0x0e;
   //turnning command pin of lcd to output
   //delay 15msec
   delay_ms(15);
   lcd_command_port.enable=0;
   lcd_command_port.data_command=0;
   lcd_command_port.read_write=0;
   lcd_data_port.data=0;
   delay_ms(2);
   lcd_write_nibble(0x03);//was 30  ddram address: 1:1bit,line:1bit,address:4bit
   delay_ms(10);//more then 4.1msec
   delay_us(150);//more then 100usec
   delay_us(100);
   lcd_write_nibble(0x02);//was 20
   while(bit_test(lcd_read_byte(),7));
   lcd_send_byte(0x28,COMMAND0);//was 0x28 portd[3:0]=x2 then portd[3:0]=x8
                     //  4 bit low nibble, ddram address=0 first line
   lcd_send_byte(0x0c,COMMAND0);//disp on
   clear_lcd;
   lcd_send_byte(0x6,COMMAND0);//entry inc
   lcd_gotoxy(1,1);
void lcd_putc( char c) {//this function works good
   switch (c) {
     case '\f'   : lcd_send_byte(1,COMMAND0);   delay_ms(2);   break;   //Clear display
     case '\n'   : lcd_gotoxy(1,2);                        break;   //Go to start of second line
     case '\b'   : lcd_send_byte(0x10,COMMAND0);               break;   //Move back one position
     default     : lcd_send_byte(c,DATA1);                  break;   //send the actual character
char lcd_getc( char location, char line) {
      char value;
    lcd_gotoxy(location,line);
    while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
    lcd_command_port.data_command=1;
    value = lcd_read_byte();
    return(value);
      return 1;
void lcd_put_string(char *string){
//put string, starting  from the curren cursor position
//assume that string not excides from lcd displayed RAM
   char index=0;
   while(string[index]!=0){
      lcd_putc(string[index++]);
void lcd_put_string_xy(char *string, char pos, char line){
   lcd_gotoxy(pos,line);
   lcd_put_string(string);
void stan_char(long *ptr,char line,char eeprom_or_flash){
//Purpose: write 16 chars, given in ptr location(eeprom or flash)
//to line of lcd, from the begining of the line
   char c,i;
   lcd_gotoxy(1,line);
/*OR:   switch(line==1) {
      case 1:lcd_send_byte(0x80,COMMAND);   //initiate lcd to write to line 1
      case 2:lcd_send_byte(0xc0,COMMAND);   //initiate lcd to write to line 2
   for (i=0;i<16;i++){
      if (eeprom_or_flash)
         c=read_program_eeprom(ptr+1);
         c=read_eeprom((char)ptr+1);
      lcd_putc(c);ptr++;
I'm using a PIC16F877A
and a crystalFontz LCD with a HD44780 compatible controller
The Data sheet can be found here http://www.crystalfontz.com/products/0802a-color/CFAH0802AYMCJP.pdf
Can anybody please see if they can see something I don't see?
Thank you.
rnielsen
PostPosted: Wed May 19, 2004 9:43 am     Reply with quote
Here is a bit of code that I have used for several years in driving these types of displays. It is set up for a 16x2 display but has remarked code that can be used for a 16x1 display. Just change it around a little if you want to use a different port.
#include <string.h>
// Pinout connections for a 4 wire interface
// LCD      MCU
// RS       PIN_A5
// R/W      PIN_E0
// E        PIN_A4 -- this pin will need a pull-up resistor
// DB4      PIN_A0
// DB5      PIN_A1
// DB6      PIN_A2
// DB7      PIN_A3
#define RS PIN_A5 // RS pin of the LCD display
#define ENB PIN_A4 // enable for the LCD display
#define RW PIN_E0   // R/W bit for the LCD display
char table1[6] = {'L','I','N','E','1','\0'};   // "LINE1"
char table2[6] = {'L','I','N','E','2','\0'};   // "LINE2"
char text[10];   // general variable used to display information to the LCD display
void pulse(unsigned int8 bits) // sends out the clock pulse to the LCD display
unsigned int8 pp;
   output_high(ENB);
   output_a(bits);
   for(pp = 0; pp < 10; pp++)
   output_low(ENB);
void bf_check(void)
unsigned int8 pp;
int1 BF = 0;
   set_tris_a(0x0F);// set bits 0-3 as inputs
   output_low(RS);
   output_high(RW);
   for(pp = 0; pp < 5; pp++)
   do
      output_high(ENB);
      if(input(PIN_A3))
         BF = 1;
         BF = 0;
      output_low(ENB);
      output_high(ENB);
      output_low(ENB);
   }while(BF);
   set_tris_a(0x00);// set all bits to outputs
void ctlnib(int8 niblet) // sends a control command to the LCD display
int8 msn, lsn;
   bf_check();
   msn = niblet & 0xF0;
   msn = msn >> 4;
   msn = msn | 0x10;
   output_low(RW);
   output_low(RS);
   pulse(msn);
   lsn = niblet & 0x0F;
   lsn = lsn | 0x10;
   pulse(lsn);
void datnib(int8 niblet) // sends a data byte to the LCD display
int8 msn, lsn;
   bf_check();
   msn = msn >> 4;
   msn = msn | 0x30;
   output_low(RW);
   output_high(RS);
   pulse(msn);
   lsn = lsn | 0x30;
   pulse(lsn);
void disline(char outstr[], int8 dline) // format is; string - line
{                                                            // displays a line of text on a 16 x 2 LCD display
int8 llg, dindex;
//int8 track; // add for a 16 x 1 display
//   track = dline; // add for a 16 x 1 display
   ctlnib(dline);
   llg = strlen(outstr);
   for(dindex = 0; dindex <= llg - 1; dindex++)
//      if(track == 0x88) // add these 4 lines for a 16 x 1 display
//         ctlnib(0xC0);
      datnib(outstr[dindex]);
//      track++; // add for a 16 x 1 display
void dischar(char outstr, int8 dline) // format is; character - position
  ctlnib(dline);
  datnib(outstr);
void clrdis(void) // clear the LCD display
   ctlnib(0x01);
void initdisp(void) // initialize the LCD display
   output_low(RW);
   delay_ms(50);
   pulse(0x03);
   delay_ms(30);
   pulse(0x03);
   delay_us(400);
   pulse(0x03);
   pulse(0x02);
   ctlnib(0x28);
   ctlnib(0x80);
   ctlnib(0x01);
   ctlnib(0x06);
   ctlnib(0x0C);
}// end of initdisp()
main()
   initdisp();
   // example commands to print text to display
   disline(table1, 0x80);// display on first line
   disline(table2, 0xC0);// display on second line
   sprintf(text, "%u", 100);   // convert a number to be displayed on LCD
   disline(text, 0x80); // now display that number on the display
Ronald
RatFink
PostPosted: Wed May 19, 2004 10:54 am     Reply with quote
Thanks Ronald, I will check it out.
But can't one of you Ultra-Smart Coding Magicians see what could be causing the problem with the driver I'm using?
This seems like the part of the driver that applies
   char address;
   if(line!=1)
     address=40;//was80
     address=0;
   address+=location;
And In my code
 lcd_gotoxy(0,2);
   lcd_putc("TEMP");
lcd_gotoxy(5,2);
It seems like I'm doing it right, but the second value keeps printing on top of the first at (0,2) instead of where it should be at (5,2).
rnielsen
PostPosted: Wed May 19, 2004 11:02 am     Reply with quote
Try using address 0x80 for the first line and 0xC0 for the second line. See what that does.
Ronald
RatFink
PostPosted: Wed May 19, 2004 11:37 am     Reply with quote
Well, I got it to work using
lcd_gotoxy(0,2);
   printf(lcd_putc, "TEMP %d", HEAT);
I was just didn't want it to have to print the word TEMP through every loop.
Charlie U
PostPosted: Wed May 19, 2004 1:01 pm     Reply with quote
After just a quick scan, in your lcd_gotoxy() function, shouldn't the address be in hex not decimal:
address = 0x40;
Just a thought?!?!
RatFink
PostPosted: Wed May 19, 2004 1:02 pm     Reply with quote
HMMM, I'll try that.
