chava
| use of WDT to save power |
Posted: Wed May 19, 2004 5:17 am |
Hello
I have a circuit which its supply may shot down for about 40 sec.
I have to keep the pic alive for that time.
now, since I have power problems I wondered if I could "help" the hardware with software - by geting into "sleep" period.
would it help?
the pic samples the high supply voltage(220VAC) .
what I want to do is - sample that pin. and if I see that there is no voltage I enter "sleep" mode. every 18msec I want to wake up (by the WDT) and check how much time passed since the supply went off.
can it be done? how?
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Wed May 19, 2004 5:35 am |
Putting the PIC in the sleep mode will significantly reduce its power consumption, but it will not keep it alive if the power supply shuts down.
40 seconds is a long time. Even if you don't have other circuitry connected to your power line and you have huge capacitor between your VCC and ground, it is still gonna be a challenge to hold the power for 40 seconds.
Since you have enough control over the process to put the PIC to sleep, you can also use this method: Save all important state information in the EEPROM and wait for the sutdown. When the power goes back up you can use that information to resume from where you stopped. |
chava
Posted: Wed May 19, 2004 5:39 am |
no, I dont have eeprom (pic12c508a)
(I edited the topic, to make myself clear, read it ) |
