#use rs232 question = received chars as numbers?
runtime
PostPosted: Mon May 17, 2004 2:55 pm     Reply with quote
Hello All,
I have a routine to receive SMS messages and I want to interpret received characters as numbers, numbers range from 15 to 3600.
When the pic receives a string, for example if I sent the message 0015, the pic will see bytes 48 48 49 53 which are the ascii decimal codes for the number. The question is how do I store in an integer variable the number I received = 15?
Thank you in advance
Peter
PostPosted: Mon May 17, 2004 3:19 pm     Reply with quote
Use the atol() function. It's in the STDLIB.H file.
See the CCS manual and also the file INPUT.C for an example.
Both of those files are in this folder: c:\Program Files\Picc\Drivers
runtime
PostPosted: Mon May 17, 2004 3:25 pm     Reply with quote
Is there another way instead of using atoi()?
Peter
PostPosted: Mon May 17, 2004 3:52 pm     Reply with quote
Use my adtol() function.
http://www.ccsinfo.com/forum/viewtopic.php?t=17563&highlight=adtol
ljbeng
PostPosted: Mon May 17, 2004 3:55 pm     Reply with quote
Hey, I'm interested in the SMS thing.... What are you doing? I have a need to connect a digital cell phone to my equipment and have the controller send an SMS through the digital phone all automatically. Have you heard of this function before?
By the way, I would subtract 0x30 from each character, check that the result is >=0 and <=9, then take the first number x 1000, add in the second x 100, the third x 10 and add in the last number.
Douglas Kennedy
PostPosted: Mon May 17, 2004 4:04 pm     Reply with quote
If there is good reason to not use tested code like atoi then roll your own
step1
set accumulator to zero
step2
read byte Ex 48 meaning a zero
multiply accumulator by 10
addin the byte and subtract 48
step 3
if there is another byte goto step2.
PostPosted: Mon May 17, 2004 4:49 pm     Reply with quote
ljbeng,
yes, I can send an SMS from the PIC, to another phone, you onl need to use the AT+CMGS command:
AT+CMGS="phone #" <enter>
type your message and send a ctrl-z
