RTC DS1302 an PIC 18F452
CCSgues
PostPosted: Sun May 16, 2004 7:08 am     Reply with quote
Has anyone experiences with maxim's DS1302 and DS32kHz.
I've connected the DS32Khz clock output directly with DS1302's X1 and X2 clock input and I'm using CCS' driverfile DS1302.c, but I got strange outputs for hour, min and sec.
Is there any bug in the soure?
#include <18F452.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
#include <DS1302.C>                             //Uhrentreiber
byte day,mth,year,dow,hour,min,sec;
const unsigned int conv[16] = {0,10,20,30,40,50,60,70,80,90,90,90,90,90,90,90 };
#define fromBCD(x) ((x & 0xf)+conv[(x>>4)])
   unsigned int toBCD(unsigned int val)
   int ctr;
   for (ctr=0;ctr<10;ctr++)
      if (val == conv[ctr])
      return(ctr<<4);
      else if (val < conv[ctr]) break;
   --ctr;
   return((val-conv[ctr])+(ctr<<4));
}        //Definiton RTC_BCD_Code ende
//                             RTD DS1302 Maxim                               //
//                                 DS1302.C                                   //
//                       Driver for Real Time Clock                           //
//    rtc_init()                                   Call after power up        //
//    rtc_set_datetime(day,mth,year,dow,hour,min)  Set the date/time          //
//    rtc_get_date(day,mth,year,dow)               Get the date               //
//    rtc_get_time(hr,min,sec)                     Get the time               //
//    rtc_write_nvr(address,data)                  Write to NVR               //
//    data = rtc_read_nvr(address)                 Read from NVR              //
byte get_bcd() {
  char first,second;
  do {
    first=getc();
  } while ((first<'0') || (first>'9'));
  putc(first);
  first-='0';
  do {
    second=getc();
  } while ((second<'0') || (second>'9'));
  putc(second);
  return((first<<4)|(second-'0'));
void set_clock()
   puts("Year 20: ");
   year=get_bcd();
   puts("Month: ");
   mth=get_bcd();
   puts("Day: ");
   day=get_bcd();
   puts("Weekday 1-7: ");
   dow=get_bcd();
   puts("Hour: ");
   hour=get_bcd();
   puts("Min: ");
   min=get_bcd();
   puts("sec");
   sec=get_bcd();
   rtc_set_datetime(day,mth,year,dow,hour,min);
   printf("\n\r Eingestelltes Datum: %2d,%2d,%2d, um %2d:%2d:%2d Uhr\n",fromBCD(day),fromBCD(mth),fromBCD(year),fromBCD(hour),fromBCD(min),fromBCD(sec));
void get_clock()
rtc_get_time(hour,min,sec);
printf("\n\r...%2d:%2d:%2d...\n",fromBCD(hour),fromBCD(min),fromBCD(sec));
rtc_init();
   set_clock();
 printf("\n\r...Begin Main...\n");
  do {
      get_clock();
     } while (TRUE);  //end true
Somkiat
PostPosted: Sun May 16, 2004 7:42 am     Reply with quote
Hi
about this question try to look this site :
http://www.geocities.com/contax_electronics/ctpic84_examples/ds1302_84.html
CCSgues
PostPosted: Sun May 16, 2004 9:56 am     Reply with quote
Is it right to connect the DS32khz's 32.768kHz output directly to DS1302's Pin 2 and 3 or do I have to connect Pin 2 to 32.768kHz output and Pin 3 to gnd?
I don't know how to connect the DS32kHz
http://pdfserv.maxim-ic.com/en/ds/DS32kHz.pdf
thx Fabian
DS32KHZ to DS1302
PostPosted: Sun May 16, 2004 5:42 pm     Reply with quote
The DS1302 data sheet tells you how it should be connected with the 32KHZ output to pin X1 and leave X2 floating.
The DS32KHZ sheet also shows you how to connect it for low curent consumption. PLEASE read the data sheets before asking.....
