Problem with ICDU-40
Urvin
PostPosted: Sat May 15, 2004 7:40 am     Reply with quote
Hi, I have a problem with ICDU-40.
When I try to program a device using ICDU-40 from within PCWH (ver:3.158) I get an ICD error that says unrecognized file format.
Any help would be appreciated.
Best Regards Urvin
Haplo
PostPosted: Sat May 15, 2004 7:47 am     Reply with quote
What is the format of the file you are trying to burn?
Urvin
PostPosted: Sat May 15, 2004 8:02 am     Reply with quote
I am trying to burn a HEX-file
Haplo
PostPosted: Sat May 15, 2004 8:09 am     Reply with quote
How have you created the HEX file? Open it in a text editor and make sure the format is correct. Or since you have PCW use the dis-assembler (Tools menu) to dis-assemble the file and see if it is in the right format.
PostPosted: Sat May 15, 2004 8:12 am     Reply with quote
The Hex file is OK because I can program it in the DEvice if I run the ICDU programmer as a stand-alone program (not within PCWH).
Haplo
PostPosted: Sat May 15, 2004 9:12 am     Reply with quote
In the Option menu check the File Formats. From CCS bugfix list:
3.160 Some COFF debug file problems are resolved
3.177 Some debugger and ICD programming issues have been resolved
Change your debug file format and recompile. This might help.
