nfs
how to pass "led" through function |
Posted: Tue May 11, 2004 9:44 am |
#define led1 PIN_A1
#define led1 PIN_A2
#define led1 PIN_A3
#define tension_maxi_touche_0 34
void calcul (ledx,int16 tension_maxi_touche_x,int16 tension_mini_touche_x,int1 ledy,int1 ledz)
void main void
calcul(led1,tension_maxi_touche_0,tension_mini_touche_0,led2,led3);
so how can i set led in the function _________________ nfs |
Neutone
Posted: Tue May 11, 2004 10:07 am |
Change
ledx
to this
Int1 ledx
Also you can not define a constant (led1) to have several values |
nfs
re |
Posted: Tue May 11, 2004 10:12 am |
i've changed this but no result _________________ nfs |
rnielsen
Posted: Tue May 11, 2004 11:28 am |
Try this:
void calcul(int8 ledx)
switch(ledx)
CASE 0:
output_high(PIN_A1);
CASE 1:
output_high(PIN_A2);
CASE 2:
output_high(PIN_A3);
default:
void main void
int8 led;
calcul(led);
Just pass the correct number for the LED you want turned on. |
nfs
re |
Posted: Wed May 12, 2004 2:04 am |
i've to pass more than one led into function like this code:
#include <16F876.h>
/* Set configuration bits in the PIC processor */
#fuses XT, NOPROTECT, NOPUT, NOWDT, NOBROWNOUT, NOLVP, NOCPD, NOWRT
//crystal, no watchdog timer, no low programming, no powerup timer, noprotect=memory protection off
#device adc=10
#device *=16
#use delay (clock=4000000) /* sets appropriate compiler constants 1µsecond instruction cycle */
#use standard_io ( a )
#use standard_io ( b )
#use standard_io ( c )
#define led1 PIN_A1 //led jaune commutateur '0'
#define led2 PIN_A2 //led verte commutateur '0'
#define led3 PIN_A3 //led rouge commutateur '0'
#define led4 PIN_A5 //led jaune commutateur 'R'
#define led5 PIN_B0 //led verte commutateur 'R'
#define led6 PIN_B1 //led rouge commutateur 'R'
#define led7 PIN_B2 //led jaune commutateur '+'
#define led8 PIN_B3 //led verte commutateur '+'
#define led9 PIN_B4 //led rouge commutateur '+'
#define led10 PIN_B5 //led jaune commutateur '-'
#define led11 PIN_B6 //led verte commutateur '-'
#define led12 PIN_B7 //led rouge commutateur '-'
#define Vpp 1024 //seuil maxi de tension
#define Vppfluct 1003 //seuil autorisé de fluctuation de la tension
#define Vppmin 973 //seuil pour lequel la tension est passée du niveau haut à un niveau plus bas*****
#define Vss 0 //seuil minimal de tension
#define Vctq 921 //seuil de chute de la tension
#define tension_mini_touche_0 0
#define tension_maxi_touche_R 790
#define tension_mini_touche_R 750
#define tension_maxi_touche_plus 523
#define tension_mini_touche_plus 463
#define tension_maxi_touche_moins 287
#define tension_mini_touche_moins 245
#define txPC PIN_C6
#define rxPC PIN_C7
#use RS232(BAUD=9600,BITS=8,XMIT=PIN_C6,RCV=PIN_C7)
#bit ADFM_BIT=0x9F.7
#bit PCFG3_BIT=0X9F.3
#bit PCFG2_BIT=0X9F.2
#bit PCFG1_BIT=0X9F.1
#bit PCFG0_BIT=0X9F.0
#byte INTCON = 0x0b //registre des interruptions
#byte PIE1 = 0x8c //registre contenant les autorisations d'interruptions
#byte PIR1 = 0x0c
#byte ADCON0 = 0x1f //registre du convertisseur
#byte ADCON1 = 0x9f //rôle des pins+justification du resultat de la conversion
#byte ADRESH = 0x1e
#byte ADRESL = 0x9e
#byte port_b = 0x06
#byte port_c = 0x07
#bit GO_DONE = ADCON0.2
#bit ADON = ADCON0.0
#bit ADIE = PIE1.6
#bit ADIF = PIR1.6
#define SET_TRIS_A = 0b00001; // PORTA AN0 entrée et les autres en sortie
#define SET_TRIS_B = 0x00; // PORTB en sortie
#define TMR1IE = PIE1.0
#define TMR1IF = PIR1.0
int16 us;
int16 ADCvaleur;
long ADCvtot;
int1 wait=true;
long Counter1;
int8 Counter2=99;
int8 counter3 =499;
int8 cnt;
#int_TIMER2
TIMER2_isr()
Counter1++;
ADIF=0;
void InitialiseADC ()
setup_port_a( RA0_ANALOG );
setup_adc( ADC_CLOCK_DIV_8 );
set_adc_channel( 0 );
delay_us(10);
#int_rtcc
isr()
cnt++;
void calcul (int1 ledx,int16 tension_maxi_touche_x,int16 tension_mini_touche_x,int1 ledy,int1 ledz)
setup_timer_2(T2_DIV_BY_4,5,5);
ADCvaleur=read_ADC();
Counter1=0;
while (Counter1<19999)
if (ADCvaleur>Vppfluct)
output_high (ledx);
if (ADCvaleur=Vppfluct)
disable_interrupts ( INT_TIMER2 );
delay_ms(10);
if ((ADCvaleur<=tension_maxi_touche_x) && (ADCvaleur>=tension_mini_touche_x))
setup_counters(RTCC_INTERNAL, RTCC_DIV_2);
enable_interrupts (INT_RTCC);
enable_interrupts ( GLOBAL );
set_rtcc (216);
do
ADCvaleur = Read_ADC(); /* read the ADC */
ADCvtot += ADCvaleur; /* add it to total, for later averaging */
while ((cnt <= counter3) && (ADCvaleur<=tension_maxi_touche_x) && (ADCvaleur>=tension_mini_touche_x)); /* increment count, is it ten counts yet? */
disable_interrupts ( INT_RTCC ); /* don't allow interrupts during display */
ADCvtot /= 500; /* division par 500 échantillons pour calculer la moyenne des tensions relevée */
setup_timer_2(T2_DIV_BY_4,10,5);
if (ADCvaleur == ADCvtot+ADCvtot*0.1)
disable_interrupts(INT_timer2);
delay_ms(20);
counter1=0;
setup_timer_2(T2_DIV_BY_4,15,5);
do
output_high(ledy);
while ((ADCvaleur>=Vppfluct) && (counter1=199));
output_high(ledz);
output_high(ledz);
if (counter1=19999)
output_high(ledz);
output_low(ledx);
void main( void )
long ADCvaleur;
long ADCvtot;
OUTPUT_B(0x00);// clear all pins on port b
ADCON0=0x81; // fosc/32, RA0, a/d off, a/d operating
ADCON1=0x8E; // an0 is a/d input, rest port a digital, internal ref, right justified
INTCON=0xc0; // enable global interrupts and peripherals
InitialiseADC();
if (ADIF ==1)
ADIF = 0;
ADCvaleur = 0;
ADCvtot = 0;
calcul(led4,tension_maxi_touche_R,tension_mini_touche_R,led5,led6);
calcul(led7,tension_maxi_touche_plus,tension_mini_touche_plus,led8,led9);
calcul(led10,tension_maxi_touche_moins,tension_mini_touche_moins,led11,led12);
