		| Author | Message |
		| .C
				| lcd_putc and printf(lcd_putc,... |
				|  Posted: Tue May 11, 2004 9:04 am |   |
				| Hi,
 I'am using this routine to print on the lcd my digits.
 Printf(LCD_PUTC...) is more expensive..
 void PrintDigit(unsigned int inp)
 outp[0] = outp[1] = outp[2] = outp[3] = outp[4] = 0;// clear the string
 while (inp > 99) {
 inp -= 100;
 outp[2]++;
 while (inp > 9) {
 inp -= 10;
 outp[3]++;
 outp[4] = inp + 0x30; // add '0' to the results
 outp[0] += 0x30;
 outp[1] += 0x30;
 outp[2] += 0x30;
 outp[3] += 0x30;
 void LCD (int N) {
 PrintDigit(N);
 if (n>99) { lcd_GOTOXY(9,1);  LCD_PUTC(OUTP[2]); }
 if (n>9)   { lcd_GOTOXY(10,1);  LCD_PUTC(OUTP[3]); }
 lcd_GOTOXY(11,1);  LCD_PUTC(OUTP[4]);
 if (n<100) {lcd_GOTOXY(9,1);  LCD_PUTC(' '); }
 if (n<9)  {lcd_GOTOXY(10,1); LCD_PUTC(' '); }
 lcd(200);  //example
 But I don't know how to print string characters
 void Print(int msgIndex) {
 int scanMSGLCD;
 char const msgLCD[7][17] = { "     Hello      ","   GO         ",
 "      DOWN      ","     UP      ",
 etc..
 IF (MSGINDEX>6) MSGINDEX=0;
 lcd_gotoxy(1,2);
 for (scanMSGLCD=0;scanMSGLCD<17;scanmsgLCD++)   {
 >>     printf(lcd_putc,"%c",msgLCD[msgIndex][scanmsgLCD]);
 Can you help me to write code for lcd character without printf ?
 Thank in advance
		| PCM programmer
				|  Posted: Tue May 11, 2004 1:36 pm |   |
				|  	  | Quote: |  	  | printf(lcd_putc,"%c",msgLCD[msgIndex][scanmsgLCD]); Can you help me to write code for lcd character without printf ?
 Can't you just do this with a loop ?   Read characters  from the
 string and send them to the lcd driver, one at a time, until you
 read an "end of string" character (ie., 0).   Then break out of
 the loop.
  	  | Code: |  	  | for(scanMSGLCD=0; scanMSGLCD < 17; scanmsgLCD++) {
 c = msgLCD[msgIndex][scanmsgLCD];
 if(c == 0)
 lcd_putc(c);
		| .C
				|  Posted: Wed May 12, 2004 2:40 am |   |
				| yes I think that it is the best way or
 do {
 ScanMSGLCD++;
 lcd_putc(C);
 } while (C!=0);
 In this case 'Do' is the best
 | You cannot post new topics in this forum You cannot reply to topics in this forum
