NUL characters in arrays
sandy wilson
PostPosted: Mon May 10, 2004 5:33 am     Reply with quote
Hello Everybody,
does anybody know of any problems with using the NUL character (0x00)in arrays using the CCS compiler version 3.089.
We are using an array to receive characters through RS485 and everything seems to work ok untill a NUL is sent then it all goes to Pot. No code posted as this is just a general [spam] for clues.
thanks
Sandyw Confused
Re: NUL characters in arrays
PostPosted: Mon May 10, 2004 5:52 am     Reply with quote
sandy wilson wrote:
Hello Everybody,
thanks
Sandyw Confused
Obvious comment.
In C, the 0 character is used as the 'end of string' marker. If you are storing characters into an array, and then trying to use any of the string functions on these (including things like %s in the printf statement), the string will be treated as terminating at this point.
Other than this, no. I have used RS485 block based transmissions, sending/receiving binary values including 0, with no problems at all.
sandy wilson
Null characters in arrays
PostPosted: Tue May 11, 2004 1:47 am     Reply with quote
Thank you Ttelmah,
The obvious was the problem. We were using a strcpy() for copying the arrays so it stopped when it reached 0x00.
These thing happen.
Sandyw Embarassed
Re: Null characters in arrays
PostPosted: Tue May 11, 2004 1:52 am     Reply with quote
sandy wilson wrote:
Thank you Ttelmah,
These thing happen.
Sandyw Embarassed
At least it was easy to find.
Glad it is working now.
