ADC trouble with the PIC 16F873
Goto page Previous  1, 2
hanckmann
OK
PostPosted: Fri May 07, 2004 5:16 am     Reply with quote
Ok, now I changes some other stuff (I am not yet shure what the problem was) and it DOES WORK !!!
I am now testing what the problem really was. I will add it in this post later.
Thanks for all your help
Best regards,
Patrick Very Happy
hanckmann
PostPosted: Fri May 07, 2004 6:14 am     Reply with quote
Now I tried to find out what the real problem was. But i still do not have a clue....
This is the code I use now in the while(FOREVER) loop (see the source code listed before). I have enabled the interrupt now !!!!
while(FOREVER)
   Setup_Adc_Ports(RA0_RA1_RA3_ANALOG);
   Setup_Adc(ADC_CLOCK_DIV_8);
   Enable_Interrupts(INT_AD);
   SET_ADC_CHANNEL(0);
   delay_us(40);
   SetMux(0);
   adc1= READ_ADC();
   SET_ADC_CHANNEL(1);
   delay_us(40);
   SetMux(2);
   adc2= READ_ADC();
   lcd_clear();
   printf(lcd_putc,"X1: %ld\nX2: %ld", adc1, adc2);
   SETUP_PORT_A(NO_ANALOGS);
   Set_Tris_A (SETPORTA);
} // end of while(FOREVER)
Everything works now with the ADC, but if somebody has a clue about what was going wrng before I would like to know it !!!
Thanks again
Patrick Wink
Haplo
PostPosted: Fri May 07, 2004 6:42 am     Reply with quote
It was probably a combination of more than one problem: Wrong oscillator fuse setting, wrong ADC clock setting, using the wrong ADC channel,...
Page 2 of 2
