ljbeng
If interested.... Code for Multiple 24LC256 |
Posted: Mon May 03, 2004 9:29 am |
I have a box that uses 8 24LC256 external eeproms. I modified 24256.c to allow for addressing all 8 chips. My board has the address line (A0,A1,A2) of the eeproms tied to +5 or ground to create a different address for each chip. With this code you can put up to 8 eeproms on the same board and get 32K bytes x 8 chips = 256K bytes of memory.
Code: | ///////////////////////////////////////////////////////////////////////////
//// Library for Multiple 24LC256 serial EEPROMs ////
//// init_ext_eeprom(); Call before the other functions are used ////
//// write_ext_eeprom(c, a, d); Write the byte d to the address a ////
//// using chip c ////
//// d = read_ext_eeprom(c, a); Read the byte d from the address a ////
//// c = chip address: Pins a0, a1, a2 of chip define address for ////
//// each 24256 chip up to 8 chips can be addressed////
//// Change the pin assignments inside the #use i2c statement ////
#use i2c(master, sda=PIN_C4, scl=PIN_C3)
#define EEPROM_ADDRESS long int
#define EEPROM_SIZE 32768
void init_ext_eeprom()
output_float(PIN_C3);
output_float(PIN_C4);
void write_ext_eeprom(BYTE chadd,long int address, BYTE data)
short int status;
chadd = (chadd<<1) + 0xa0;
i2c_start();
i2c_write(chadd);
i2c_write(address>>8);
i2c_write(address);
i2c_write(data);
i2c_stop();
i2c_start();
status=i2c_write(chadd);
while(status==1)
i2c_start();
BYTE read_ext_eeprom(BYTE chadd,long int address) {
BYTE data;
i2c_start();
i2c_write(chadd);
i2c_write(address);
i2c_start();
chadd = chadd | 1;
i2c_write(chadd);
data=i2c_read(0);
i2c_stop();
return(data);
Humberto
Posted: Mon May 03, 2004 9:37 am |
Hi ljbeng,
Good
Thanks for upload & share !!!
Humberto |
Gabriel Caffese
Joined: 09 Oct 2003 Posts: 39 Location: LA PLATA, ARGENTINA
Thanks for sharing, but... |
Posted: Mon May 03, 2004 10:17 am |
Ljbeng,
Thanks for sharing your code, but take care that 24256 eeproms are 32kbyte size, so 8*32kb = 256kbytes !! |
ljbeng
Posted: Mon May 03, 2004 10:31 am |
Your right, bad math on my part. I thought that sounded low. |
