Temperature sensor output to PIC
Arfaq
PostPosted: Fri Apr 30, 2004 7:55 am     Reply with quote
Hi im a new CCS user and a wanted to know if it was possible to read the output voltage (mV) from a temperature sensor by the PIC, which will decode the voltage to temp?? Please could you give me a example of the code and the requirements. thank you.
Arfaq Ahmed
Couch
PostPosted: Fri Apr 30, 2004 10:04 am     Reply with quote
Search for LM34 and you will get a few ideas, and some sample code. There are a lot more examples if you use a serial or I2C device...
SherpaDoug
PostPosted: Fri Apr 30, 2004 12:43 pm     Reply with quote
If you want to see how to do it with real primitive hardware I would recommend Microchip application note AN512 which connects a thermistor to PIC digital pins with resistors and a cap and uses the timer to measure accurate temperature. AN513 uses simillar principles for general voltage measurement.
Steve H
PostPosted: Sun May 02, 2004 10:10 am     Reply with quote
Here is a link to a project that I did a while back,
http://www.geocities.com/hagtronics/thermometer.html
If I was to do this today I would use a 16F873 with the 10 bit A/D and a LM50 temp sensor. If you scale the A/D reference on the 873 to 2.5 volts and use an LM50 you can do away without the OPAMP.
Steve H.
Steve H
PostPosted: Sun May 02, 2004 10:11 am     Reply with quote
If I was to do this today I would use a 16F873 with the 10 bit A/D and a LM50 temp sensor. If you scale the A/D reference on the 873 to 2.5 volts and use an LM50 you can do away with the OPAMP.
Steve H.
