Problem of button programming
xinyh
PostPosted: Sun Apr 25, 2004 4:33 am     Reply with quote
Hi Dear All,
I try a button programming of PIC16F877, now the problem is when I switch on, A1 is in high already, what ever which button is pressed, it never change. My programming is below, anyone can help me? thanks very much!
// button.c
// To develop a matrix keyboard by using RB1, RB2 & RB4, RB5
// B4,B5 are in column, B1,B2 are in line
// Keyboard works in polling style, set B1=L, B2=H, then test B4, B5
// If B5=L,B4=H, or B5=H, B4=L,then the pressed button can be detected
// so B1, B2 are output, B4,B5 are input
#include "C:\pic16\button.h"
#define OUTB1 PIN_B1
#define OUTB2 PIN_B2
#define INPB4 PIN_B4
#define INPB5 PIN_B5
int j=0x00;
int KEYSERVE()
output_low(OUTB1);
if(!INPB4) j=0x01;
if(!INPB5) j=0x03;
output_low(OUTB2);
if(!INPB4) j=0x02;
if(!INPB5) j=0x04;
if((INPB4)&&(INPB5))
break; // Wait key to be released
return(j);
int KEYSCAN()
output_low(OUTB1);
if((!INPB4)||(!INPB5))
} // Wait for button is pressed
delay_ms(10);
KEYSERVE(); // If still there are button is pressed, call keyserve()
else j=0x00;
output_high(OUTB1);
return(j);
KEYSCAN();
if(j!=0x00)
switch (j){
case(0x01): output_high(PIN_A0);
case(0x02): output_high(PIN_A1);
case(0x03): output_high(PIN_A2);
case(0x04): output_high(PIN_A3);
default: break;
xinyh
PostPosted: Mon Apr 26, 2004 9:42 am     Reply with quote
Hi All,
Got it. Just use !input(PIN_B1) instead of (!PIN_B1).
Humberto
PostPosted: Mon Apr 26, 2004 10:20 am     Reply with quote
Hi xinyh,
If you enable the WARNING ERRORS in the compiler options, the compiler would generate an error file complaining:
>>> Warning 203 "C:\PICC\key01.C" Line 81(1,1): Condition always TRUE
>>> Warning 204 "C:\PICC\key01.C" Line 82(1,1): Condition always FALSE
>>> Warning 203 "C:\PICC\key01.C" Line 85(1,1): Condition always TRUE
>>> Warning 204 "C:\PICC\key01.C" Line 86(1,1): Condition always FALSE
>>> Warning 203 "C:\PICC\key01.C" Line 89(1,1): Condition always TRUE
>>> Warning 203 "C:\PICC\key01.C" Line 91(1,1): Condition always TRUE
>>> Warning 203 "C:\PICC\key01.C" Line 102(1,1): Condition always TRUE
>>> Warning 203 "C:\PICC\key01.C" Line 105(1,1): Condition always TRUE
>>> Warning 203 "C:\PICC\key01.C" Line 110(1,1): Condition always TRUE
>>> Warning 203 "C:\PICC\key01.C" Line 122(1,1): Condition always TRUE
      Memory usage:   ROM=3%      RAM=7% - 7%
      0 Errors,  10 Warnings.
I just put some expresion in the rigth form:
static int8  key_pressed;
int j=0x00;
int KEYSERVE()
  output_low(OUTB1);
  if(!input(INPB4)) j=0x01;
  if(!input(INPB5)) j=0x03;
  output_low(OUTB2);
  if(!input(INPB4)) j=0x02;
  if(!input(INPB5)) j=0x04;
  key_pressed = FALSE;
  do
     if((input(INPB4))&&(input(INPB5)))
         key_pressed = TRUE;           // Wait key to be released
    }while(!key_pressed);
  return(j);
int KEYSCAN()
   do
      output_low(OUTB1);
      if((!input(INPB4))||(!input(INPB5)))
         key_pressed = TRUE;        // Wait for button is pressed
         delay_ms(10);
    else j=0x00;
    output_high(OUTB1);
    return(j);
       KEYSCAN();
       if(j!=0x00)
          switch (j)
            default: break;
And the actual error file:
>>> Warning 203 "C:\PICC\key02.C" Line 114(1,1): Condition always TRUE
      Memory usage:   ROM=4%      RAM=5% - 5%
      0 Errors,  1 Warnings.
1 Warnings because the expresion: while(1)
Regards,
Humberto
PostPosted: Wed Apr 28, 2004 12:04 am     Reply with quote
Hi Humberto,
Now it works very well. Thanks very much!
Btw, I can't find the ENABLE WARNING ERRORS in the C compiler, maybe the version is different!
Best Regards,
Xinyh
Humberto
PostPosted: Wed Apr 28, 2004 9:54 am     Reply with quote
Hi xinyh,
Open the CCS Help, in Overview, open Invoking the Compiler line compiler Options:
+EW = SHOW WARNING MESSAGES
Humberto
PostPosted: Wed Apr 28, 2004 9:34 pm     Reply with quote
Hi Humberto,
It's interesting, but how to edit it? Appreciate to show me the detail, pls.
Best Regards,
Xinyh
Humberto
PostPosted: Thu Apr 29, 2004 9:22 am     Reply with quote
Double click in CCSC.CHM Evil or Very Mad
Itīs an HTML file.
Humberto
PD: Game is over
