		| Author | Message |
		| chingB
				| I2C Help-- error data return |
				|  Posted: Fri Apr 23, 2004 7:54 am |   |
				| Hi,
 I got an I2C application and my code is listed below:
  	  | Code: |  	  | #define REC_MARKER   (0xb0)
 #define FRAM_SDA     PIN_C4      // i2c data line
 #define FRAM_SCL      PIN_C3      // i2c clock line
 // total external memory size
 #define FRAM_TOTAL_MEM_SIZE   131072
 // block length for one transaction (data size)
 #define BLOCK_LENGTH  16
 // define I2C read/write address
 #define FRAM_WR_ADDR  0xA0        // initial FRAM write address at 1st chip
 #define FRAM_RD_ADDR  0xA1        // initial FRAM read address at 1st chip
 #define ENABLE_FRAM_WP()                       \
 output_high(PIN_C5)       // enable FRAM write protect
 #define DISABLE_FRAM_WP()                      \
 output_low(PIN_C5)        // disable FRAM write protect
 // for I2C read/write routines
 #define I2C_IDLE()                             \
 while ((SSPCON2 & 0x1F) || (SSP_RW))
 #define I2C_START()                            \
 SSP_SEN = 1;                           \
 while (SSP_SEN) {                      \
 #asm nop #endasm                    \
 #define I2C_RESTART()                          \
 SSP_RSEN = 1;                          \
 while (SSP_RSEN) {                     \
 #asm nop #endasm                    \
 #define I2C_STOP()                             \
 SSP_PEN = 1;                           \
 while (SSP_PEN) {                      \
 #asm nop #endasm                    \
 #define I2C_WRITE(x)                           \
 SSPBUF = (x);                          \
 while (SSP_BF) {                       \
 #asm nop #endasm                    \
 I2C_IDLE()
 #define I2C_READ(x)                            \
 SSP_RCEN = 1;                          \
 while (SSP_RCEN) {                     \
 #asm nop #endasm                    \
 SSP_ACKDT = (x);                       \
 SSP_ACKEN = 1;                         \
 while (SSP_ACKEN) {                    \
 #asm nop #endasm                    \
 static BOOLEAN  I2C_Device_Ready(unsigned int8 uID);
 do
 // Important to clear these bits before we attempt to write
 BCLIF = 0;
 SSP_WCOL = 0;
 I2C_IDLE();     // ensure module is idle
 I2C_START();
 } while (BCLIF);
 I2C_WRITE(uID);    // send memID
 if (!SSP_ACKSTAT)  // test for ACK condition, if received
 return (TRUE);
 return (FALSE);    // no ACK
 // Write one block of data to the FM24C256 chip
 void write_fram_block(
 unsigned int32 uAddress,      // FM24C256 address to write data
 unsigned int8 Block,          // block length or page length to write
 unsigned int8 *data)          // pointer to data buffer for write
 unsigned int8 uControl;       // FM24C256 chipselect
 unsigned int8 uI;
 // chipselect for specific FM24C256 to write
 uControl = (FRAM_WR_ADDR | make8(uAddress<<2,2)) & 0xFE;
 DISABLE_FRAM_WP();            // write protect is disabled
 while (!I2C_Device_Ready(uControl));
 I2C_WRITE((make8(uAddress,1)) & 0x7F);  // send MSB of mem address
 I2C_WRITE(make8(uAddress,0));           // send LSB of mem address
 for (uI=0; uI<Block; uI++) {
 I2C_WRITE(*data++);        // send data to FM24C256
 I2C_STOP();
 ENABLE_FRAM_WP();             // write protect is enabled/engage
 // Write one byte data to FM24C256 chip
 void write_fram_Byte(
 unsigned int32 uAddress,      // FRAM address to write data
 unsigned int8 uData)          // byte written to FRAM
 I2C_WRITE(uData);  // send data
 I2C_STOP();
 // Read one block of data from FM24C256 chip
 void read_fram_block(
 unsigned int32 uAddress,      // FM24C256 address to read data
 unsigned int8 Block,          // block length or one page write
 unsigned int8 *data)          // pointer to gaReadMemRFbuf to store data
 // chipselect for specific FM24C256 to read
 I2C_RESTART();
 I2C_WRITE(uControl | 0x01);   // set address for read
 while (Block > 1) {
 I2C_READ(0);
 *data = SSPBUF;
 data++;
 Block--;
 I2C_READ(1);
 *data = SSPBUF;
 I2C_STOP();
 // Read one byte data from FM24C256 chip
 unsigned int8 read_fram_byte(
 unsigned int32  uAddress)    // FM24C256 address to read data
 I2C_RESTART();
 I2C_READ(1);
 I2C_STOP();
 return (SSPBUF);  // return with data
 void ConfigureI2C()
 // initialize FRAM clock and data I/O
 output_float(FRAM_SCL);    // set clock lines to input
 output_float(FRAM_SDA);    // set data lines to input
 // Configure the MSSP as an I2C Port for PIC18F452
 // Relevant port pins configured as inputs
 SSP_SSPEN = 1;   // Enable I2C mode
 SSP_SSPM3 = 1;   // setup I2C mode
 SSP_SSPM2 = 0;
 SSP_SSPM1 = 0;
 SSP_SSPM0 = 0;
 SSPCON2 = 0;
 SSP_SMP = 0;
 SSP_CKE = 0;     // Set I2C Levels
 // Set I2C Speed. The formula is:
 // SSPADD value = (Fosc/(i2c clock speed * 4)) -1
 // Examples:
 // SSPADD values for an Fosc of 8 MHz:
 // *** NOTE: If you run your PIC at a different Fosc, then you
 // *** you need to calculate new values.
 // For an i2c clock of 100 KHz, SSPADD = 19
 // For an i2c clock of 400 KHz, SSPADD = 4
 // For an i2c clock of 1 MHz, SSPADD = 1
 SSPADD = 4;      // 1 MHz i2c clock at 20MHz oscillator
 SSP_SMP = 1;     // disable slew rate control for 1 MHz operation ONLY
 // *** NOTE: Based on my oscilloscope readings, the i2c clock
 // *** speed seems to run a little slower than what the formula says.
 // *** For example, "400 KHz" is really 370 KHz or so.
 // *** "1 MHz" is really running slightly less than that speed.
 void init_mcu()      // MCU Initialization Routine
 delay_ms(2000);   // delay for 2 seconds (stabilized MCU?)
 ConfigureI2C();   // initialize I2C I/O and configure for I2C mode
 setup_adc_ports(NO_ANALOGS);    // setup PortA to digital I/O
 The code below is my test program:
  	  | Code: |  	  | main()
 unsigned int8 i;
 char tempbuffer[16];
 char temp2=0;
 unsigned int8 minutes;
 unsigned int8 hours;
 unsigned int8 mthdays;
 unsigned int8 months;
 unsigned int8 years;
 unsigned int8 y2kyrs;
 unsigned int32 addr=0;
 unsigned int16 cnt=0;
 unsigned int16 logcount=0;
 init_mcu();
 output_low(PIN_A0);
 for (i=0; i<16; i++)
 tempbuffer[i]=0;
 minutes = 30;     // 00 ~ 59 minutes
 hours   = 14;     // 00 ~ 23 hours, military format
 mthdays = 15;     // 01 ~ 31 day(s) of the month
 months  = 11;     // 01 ~ 12 months, 1-Jan ... 12-Dec
 years   = 04;     // 00 ~ 99 2-digit year within a century
 y2kyrs  = 20;     // 20 ~ 99 Y2K year or century
 for (cnt=0; cnt<8192; cnt++){
 addr = cnt*16;
 write_fram_block(addr,16,tempbuffer);
 tempbuffer[0] = (months & 0x0f) | REC_MARKER;
 tempbuffer[1] = mthdays;
 tempbuffer[2] = y2kyrs;
 tempbuffer[3] = years;
 tempbuffer[4] = '0';
 tempbuffer[5] = '1';
 tempbuffer[6] = '2';
 tempbuffer[7] = '3';
 tempbuffer[8] = '4';
 tempbuffer[9] = '5';
 tempbuffer[10] = '6';
 tempbuffer[11] = '7';
 tempbuffer[12] = '8';
 tempbuffer[13] = '9';
 tempbuffer[14] = hours;
 tempbuffer[15] = minutes;
 printf("\r\n\r\n");
 for (cnt=1000; cnt<3600; cnt++){
 addr = cnt*16;
 printf("\r\n\r\n");
 temp2=0;
 for (cnt=0;cnt<8192;cnt++){
 addr = cnt*16;
 temp2 = read_fram_byte(addr);
 temp2 = temp2 & 0xf0;
 if (temp2 == REC_MARKER)
 logcount++;
 printf("\r\nLogCount=%lu",logcount);
 printf("\r\n\r\n");
 while (TRUE);
 My application is like this... I write a 16byte data to the FRAM with the 1st byte of the array is and'ed with 0x0f then or'ed with 0xb0.
 Then I scan the entire 4 FRAM chip reading the 1st byte of 16 byte data for 0xb0 and increment the FRAM reading by 16bytes...
 If 0xb0 found it increment the log counter....
 My problem really is that I got an incorrect value of log count.
 I need ur help guys... I can't figure out the problem...
 BTW, I have four(4) FM24C256 from ramtron with a total records of 8192 where each record consist of 16bytes data. I run this on PIC18F452 at 20MHz using PCWH v3.188.
 In addition, I'm using linear addressing in reading the entire 4 FRAM chips.
 Thank u.
		| chingB
				|  Posted: Fri Apr 23, 2004 5:18 pm |   |
				| Anyone can help me with my problem?
 Thnx
		| Guest
				| FRAM linear addressing |
				|  Posted: Fri Apr 23, 2004 10:16 pm |   |
				| Quote: In addition, I'm using linear addressing in reading the entire 4 FRAM chips.
 End quote:
 You cannot linear address across chips. each chip starts at 0 and ends at 32767
 You have to take care of the linear addressing.
 Anyway, there are plenty of code samples on this forum, search for FRAM or EEPROM both will works just don't bother with the delay for the FRAM.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
