TC74 problem
TC74 problem
PostPosted: Mon Apr 19, 2004 3:06 pm     Reply with quote
Hello!
I use a TC74A0 i2c temparature IC from Microchip. My problem is that reading temparature gives me different results altough the remparature should be relatively constant between two readings (2 seconds). This is my code so far:
#ifndef I2C_SDA
#define I2C_SDA  PIN_C4
#define I2C_SCL  PIN_C3
#endif
#use i2c(master, slow, sda=I2C_SDA, scl=I2C_SCL)
#include "..\mytypes.h"
// TC74 COMMANDS
#define TC74_CMD_R_TEMP         0x00      //read temp
#define TC74_CMD_RW_CFG         0x01      //read/write config
// TC74 CONFIG REGISTER BITS
#define TC74_CFG_SET_STANDBY   0x80      //read/write   1=standby, 0=normal
#define TC74_CFG_DTAREADY      0x40      //read only      1=ready, 0=not ready
#define TC74_I2C_ADDRESS      0x00
#define TC74_I2C_BASEADDR      0x9E
#define TC74_I2C_MINADDR      0x90      //smallest i2c address for tc74
#define TC74_I2C_MAXADDR      0x9E      //largest i2c address for tc74
//                                  3.3V     5V
//      ADDR      ADDR    Part Nbr    Device   Device
//    (binary)    (hex)               Marking  Marking
//   1001 0000     90     TC74A0      V0xx     U0xx
//   1001 0010     92     TC74A1      V1xx     U1xx
//   1001 0100     94     TC74A2      V2xx     U2xx
//   1001 0110     96     TC74A3      V3xx     U3xx
//   1001 1000     98     TC74A4      V4xx     U4xx
//   1001 1010     9A     TC74A5      V5xx     U5xx
//   1001 1100     9C     TC74A6      V6xx     U6xx
//   1001 1110     9E     TC74A7      V7xx     U7xx
void tc74_i2cWrite(byte addr, byte cmd, byte value);
byte tc74_i2cRead(byte addr, byte cmd);
void tc74_i2cSearch();
void tc74_setStandby(byte addr, bool onoff);
void tc74_init();
byte tc74_getTemp(byte addr);
float tc74_rawTemp2Float(byte w);
void tc74_printTemp(byte addr);
void tc74_i2cWrite(byte addr, byte cmd, byte value) {
   i2c_start();         //Start condition
   i2c_write(addr | I2C_DOWRITE);      //write
   i2c_write(cmd);      //Low byte of command
   i2c_write(value);      //high byte
   i2c_stop();            //Stop condition
byte tc74_i2cRead(byte addr, byte cmd) {
   byte res=0x00;
   i2c_start();
   i2c_start();
   i2c_write(addr | I2C_DOREAD);      //read
   res = i2c_read(0);   //0 indicates do not ack.
   i2c_stop();
   return res;
void tc74_i2cSearch() {
   byte b1,b2;
   printf("\n\rI2C device-search:");
   for(b1=TC74_I2C_MINADDR; b1<=TC74_I2C_MAXADDR; b1+=2) {
      i2c_start();             // Start condition
      b2 = i2c_write(b1);      // Device address
      i2c_stop();              // Stop condition
      if (!b2)
         printf("\n\rfound dev. addr.: 0x%X", b1);
void tc74_setStandby(byte addr, bool onoff) {
   if (onoff)
      tc74_i2cWrite(addr, TC74_CMD_RW_CFG, TC74_CFG_SET_STANDBY);
      tc74_i2cWrite(addr, TC74_CMD_RW_CFG, 0);
//   printf("\n\rset tc74 standby to %d: %x", onoff, tc74_i2cRead(addr, TC74_CMD_RW_CFG));
void tc74_init() {
   byte b1,b2;
      if (!b2) {
         printf("\n\rfound TC74 dev. @ addr.: 0x%X", b1);
         tc74_setStandby(b1, false);
byte tc74_getTemp(byte addr) {
   byte b;
//   tc74_setStandby(0x90, false);
   do {
      delay_ms(1);
      b = tc74_i2cRead(addr, TC74_CMD_RW_CFG);
   } while (!(b & TC74_CFG_DTAREADY));
   delay_ms(1);
   b = tc74_i2cRead(addr, TC74_CMD_R_TEMP);
//   tc74_setStandby(0x90, true);
   return b;
float tc74_rawTemp2Float(byte w) {      //convert the RAW temp (2's compl.) value to float °C
   byte tmp, temp_lsb,temp_msb;
   float ftemp = +1;
   if (w >= 80) {             //negative
      w = (~w)+1;      //2s complement
      ftemp = -1;
   ftemp *= w; // + (temp_lsb & 0x0F) * 0.0625;
   return ftemp;
//(TC74_I2C_BASEADDR | (TC74_I2C_ADDRESS & 0x03))
void tc74_printTemp(byte addr) {
   byte b;
   b = tc74_getTemp(addr);
   printf("\n\ri2cRawTemp=0x%x", b);
   printf("\n\rrawTemp2float=%3.0f", tc74_rawTemp2Float(b));
The output (after 1x'i' and 5x't') is:
* TC74 0.30 *
i - init
t - printTemp
1 - standbyMode
2 - normalMode
found TC74 dev. @ addr.: 0x90
i2cRawTemp=0x25
rawTemp2float=36
i2cRawTemp=0x25
rawTemp2float=36
i2cRawTemp=0x1c
rawTemp2float=27
i2cRawTemp=0x20
rawTemp2float=31
i2cRawTemp=0x24
rawTemp2float=35
I don't know where the problem is. Hardware should be OK (the IC is recognized on the i2c bus).
Who can help me?
Neutone
PostPosted: Mon Apr 19, 2004 3:35 pm     Reply with quote
This worked for me
/*             Read Temp on a TC74                        */
void Read_Temperature(void)
{  int16 Temperature;
   if(Get_Temp)
   {  Get_Temp=0;
      i2c_Start();                                          // Set a START condition I2C Bus
      i2c_Write(0b10011010);                                // Address and Write Flag
      i2c_Write(0x00);                                      // Temperature Register
      i2c_Write(0b10011011);                                // Address and Read Flag
      Temperature = i2c_Read();                             // Read Teperature
      i2c_stop();
      if(Temperature<128)
      {  Temperature+=273;                                  // Make it a kelvin reading
      {  Temperature+=273+0xFF00;                           // Make it a kelvin reading
PostPosted: Mon Apr 19, 2004 3:59 pm     Reply with quote
I would try a more simple test program. Here is one that I made
for the TCN75, which is a similar chip. It displays this output:
Start
Reading Temperature
Temp = 26
Temp = 28
Temp = 28
Temp = 27
Temp = 27
Temp = 28
Temp = 27
Temp = 26
Temp = 26
Temp = 27
Temp = 27
Temp = 27
Temp = 27
Temp = 27
It's not perfect, but it doesn't jump around as much as your
output does. (I have a heater running near the board. That's
why it's so warm).
#include <18F458.H>
#fuses XT, NOPROTECT, PUT, NOBROWNOUT, NOWDT, NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, errors)
#define TCN75_SDA PIN_C0
#define TCN75_SCL PIN_C1
#use i2c(Master, SDA=TCN75_SDA, SCL=TCN75_SCL)     // Software i2c
// DEFINES
// TCN75 i2c addresses
#define TCN75_I2C_WRITE_ADDR  0x90
#define TCN75_I2C_READ_ADDR   0x91
// TCN75 register addresses
#define TCN75_TEMP_REG_ADDR    0
#define TCN75_CONFIG_REG_ADDR  1
#define TCN75_THYST_REG_ADDR   2
#define TCN75_TSET_REG_ADDR    3
#define TCN75_CONFIG_VALUE     0x1A    // From Microchip TB052 appnote
// FUNCTION PROTOTYPES
void TCN75_init(void);
char TCN75_read_temperature(void);
char result;
printf("Start\n\r");
TCN75_init();
printf("Reading Temperature\n\r");
   result = TCN75_read_temperature();
   printf("Temp = %d \n\r", result);
 output_float(TCN75_SDA);
 output_float(TCN75_SCL);
 i2c_start();
 i2c_write(TCN75_I2C_WRITE_ADDR);
 i2c_write(TCN75_CONFIG_REG_ADDR);
 i2c_write(TCN75_CONFIG_VALUE);
 i2c_stop();
// Read the temperature and return the integer
// portion as a char.  The "1/2 degree" portion
// of the result is discarded and not returned.
// We don't need that level of precision.
 char msb;
 char lsb;
 i2c_start();
 i2c_write(TCN75_TEMP_REG_ADDR);
 i2c_start();
 i2c_write(TCN75_I2C_READ_ADDR);
 msb = i2c_read();
 lsb = i2c_read(0);
 i2c_stop();
 return(msb);
// end of program
reply
PostPosted: Mon Apr 19, 2004 5:45 pm     Reply with quote
thanks for your code. but the temp still jumps. Also if i use different chips. (also different address class)
what i2c pullups do you use?
PostPosted: Mon Apr 19, 2004 5:53 pm     Reply with quote
I'm using 3.3K pullups, going to +3.3v.
(Vdd = +3.3v on this board).
