using CAN bus
berler_d
using CAN bus
PostPosted: Tue Apr 13, 2004 7:34 am     Reply with quote
Hi All,
I several questions about the CAN bus using CCS:
1. where I can find example code ?
2. Is there a driver for the CAN bus ?
- What is the max distance for using CAN ?
Thanks,
CAN
PostPosted: Tue Apr 13, 2004 12:37 pm     Reply with quote
If you buy the CCS compiler the CAN drivers and examples are provided with the compiler.
The CAN standards define the distances.
valemike
also...
PostPosted: Tue Apr 13, 2004 3:43 pm     Reply with quote
By the way, you can also buy a CAN demo board from CCS if you look at the website.
-Mike
PostPosted: Tue Apr 13, 2004 11:40 pm     Reply with quote
- What is the product version includes the CAN driver and example?
- What is the actual distance ? 200m ?
(pic with CAN and external microchip CAN driver ?)
Thanks,
CAN Info
PostPosted: Wed Apr 14, 2004 7:18 am     Reply with quote
Depending on speed requirements you can go as much as 6 Kilometers.
If you are a registered CCS compiler user contact CCS and they should send you the files. They have been in the last 10-15 versions as far as I know.
PostPosted: Wed Apr 14, 2004 12:17 pm     Reply with quote
Thanks for the answer.
