MMC or CF memory ?
Hans Wedemeyer
MMC or CF memory ?
PostPosted: Fri Apr 09, 2004 4:51 pm     Reply with quote
New project requires a lot of storage.
The CF card seems easy enough to use, but the hardware has 50 pins and can become an assembly nightmare.
The MMC card looks a lot better with regards hardware.
Has anyone used the MMC card in SPI mode ?
Appreciate a few tips ...
Hans Wedemeyer
Douglas Kennedy
PostPosted: Sun Apr 11, 2004 9:10 pm     Reply with quote
Not sure if the private message thing is working...
Thanks for the help.
hansw
Pete Smith
View user's profile Send private message Visit poster's website MSN Messenger ICQ Number
Re: MMC or CF memory ?
PostPosted: Mon Apr 12, 2004 5:09 am     Reply with quote
Seemed to miss this posting last weel.
Yes, I've used MMC card in SPI mode. Seems to work perfectly.
There was code posted on here a while ago which showed how to use an MMC card as flat storage (a search should bring it up).
All I can say is that I only managed to get it to work by initialising the card and _then_ checking its ID's. Until I did this, it wouldn't function fully.
Can't really say more than that, because I didn't have a great deal of trouble making it work.
I'm actually soak-testing an MMC storage system right here, now. Sampling at 1000 times a second onto a FAT16 formatted card. I'm hoping it's going to fill the card up, and then beep to say "Card full" rather than "Why is there no space left!".
Pete.
horizontech
PostPosted: Mon Apr 12, 2004 11:44 am     Reply with quote
HI !
I looking to use a MCC or SD card ad data storage
What is the speed rate for write in MMC card in SPI mode ?
Where a can find specification for SPI mode ?
I am interest to buy if you have a Prebuild library for use in CCS Compiler ! for SPI SD CARD
Alain Tanguay
Thankls
PostPosted: Mon Apr 12, 2004 8:36 pm     Reply with quote
horizontech wrote:
HI !
Alain Tanguay
Thanks for the input. I also recieved some private help.
The project must work at -40oC ! and I'm finding only SD cards rated at -20oC !
I want to avoid the CF cards (which are rated at -40oC) becasue of the assembly hassles.
Good luck with your project.
Hans W
